Ogre2 render engine class. A singleton class that manages the underlying ogre2 render engine, loads its plugins, and creates resources needed for the engine to run. More...
#include <Ogre2RenderEngine.hh>
virtual ~Ogre2RenderEngine ()
void AddResourcePath (const std::string &_uri) override
 Add path to resource in ogre2's resource manager. More...
std::string CreateRenderWindow (const std::string &_handle, const unsigned int _width, const unsigned int _height, const double _ratio, const unsigned int _antiAliasing)
std::vector< unsigned int > FSAALevels () const
 Get a list of all supported FSAA levels for this render system. More...
Ogre2IgnHlmsCustomizations & HlmsCustomizations ()
 Retrieves Hlms customizations for tweaking them. More...
Ogre::HlmsPbsTerraShadows * HlmsPbsTerraShadows () const
virtual Ogre::Root * OgreRoot () const
 Get the ogre2 root object. More...
Ogre::Window * OgreWindow () const
 return the ogre window More...
Ogre::v1::OverlaySystem * OverlaySystem () const
Ogre::CompositorWorkspaceListener * TerraWorkspaceListener () const
- Public Member Functions inherited from BaseRenderEngine
virtual ~BaseRenderEngine ()
virtual ScenePtr CreateScene (const std::string &_name) override
virtual ScenePtr CreateScene (unsigned int _id, const std::string &_name) override
virtual void DestroyScene (ScenePtr _scene) override
virtual void DestroySceneById (unsigned int _id) override
virtual void DestroySceneByIndex (unsigned int _index) override
virtual void DestroySceneByName (const std::string &_name) override
virtual void DestroyScenes () override
virtual bool Fini () override
virtual bool HasScene (ConstScenePtr _scene) const override
virtual bool HasSceneId (unsigned int _id) const override
virtual bool HasSceneName (const std::string &_name) const override
virtual bool Headless () const override
 Get headless mode. More...
virtual bool Init () override
virtual bool IsInitialized () const override
virtual bool IsLoaded () const override
virtual bool Load (const std::map< std::string, std::string > &_params={}) override
virtual RenderPassSystemPtr RenderPassSystem () const override
virtual ScenePtr SceneById (unsigned int _id) const override
virtual ScenePtr SceneByIndex (unsigned int _index) const override
virtual ScenePtr SceneByName (const std::string &_name) const override
virtual unsigned int SceneCount () const override
virtual void SetHeadless (bool _headless) override
- Public Member Functions inherited from RenderEngine
virtual ~RenderEngine ()
virtual ScenePtr CreateSceneImpl (unsigned int _id, const std::string &_name) override
 Create a scene. More...
virtual bool InitImpl () override
 Initialize the render engine. More...
virtual bool LoadImpl (const std::map< std::string, std::string > &_params) override
 Engine implementation of Load function. More...
virtual SceneStorePtr Scenes () const override
 Get a pointer to the list of scenes managed by the render engine. More...
- Protected Member Functions inherited from BaseRenderEngine
 BaseRenderEngine ()
virtual unsigned int NextSceneId ()
virtual void PrepareScene (ScenePtr _scene)
- Protected Member Functions inherited from SingletonT< Ogre2RenderEngine >
 SingletonT ()
virtual ~SingletonT ()
- Static Public Member Functions inherited from SingletonT< Ogre2RenderEngine >
static Ogre2RenderEngine * Instance ()
- Protected Attributes inherited from BaseRenderEngine
bool initialized = false
bool isHeadless = false
bool loaded = false
unsigned int nextSceneId
RenderPassSystemPtr renderPassSystem
 Render pass system for this render engine. More...
std::vector< std::string > resourcePaths
 a list of paths that render engines use to locate their resources More...
std::string winID = ""
 ID from a external window. More...
◆ ~Ogre2RenderEngine()
virtual ~Ogre2RenderEngine ( )
◆ AddResourcePath()
void AddResourcePath ( const std::string &  _uri)
[in]_uriResource path in the form of an uri
Reimplemented from BaseRenderEngine.
◆ CreateRenderWindow()
std::string CreateRenderWindow ( const std::string &  _handle,
[in]_handleHandle of native window which the render window will attach
[in]_widthWidth of render window
[in]_heightHeight of render window
[in]_ratioDevice pixel ratio (typically needed for retina displays)
[in]_antiAliasingAnti-aliasing level
◆ CreateSceneImpl()
virtual ScenePtr CreateSceneImpl ( unsigned int  _id,
const std::string &  _name
Create a scene.
[in]_idUnique scene Id
[in]_nameName of scene
Implements BaseRenderEngine.
True if the render-engine was successfully destroyed
◆ FSAALevels()
std::vector<unsigned int> FSAALevels ( ) const
a list of FSAA levels
◆ HlmsCustomizations()
Ogre2IgnHlmsCustomizations& HlmsCustomizations ( )
Ogre HLMS customizations
◆ HlmsPbsTerraShadows()
Ogre::HlmsPbsTerraShadows* HlmsPbsTerraShadows ( ) const
◆ InitImpl()
virtual bool InitImpl ( )
True if the operation is successful
◆ IsEnabled()
◆ LoadImpl()
virtual bool LoadImpl ( const std::map< std::string, std::string > &  _params)
◆ Name()
The render-engine name
Implements RenderEngine.
◆ OgreRoot()
virtual Ogre::Root* OgreRoot ( ) const
ogre2 root object
◆ OgreWindow()
Ogre::Window* OgreWindow ( ) const
◆ OverlaySystem()
Ogre::v1::OverlaySystem* OverlaySystem ( ) const
◆ Scenes()
virtual SceneStorePtr Scenes ( ) const
list of scenes
◆ TerraWorkspaceListener()
Ogre::CompositorWorkspaceListener* TerraWorkspaceListener ( ) const
