ShaderParam Class Reference
a variant type that holds params that can be passed to a shader More...
#include <ShaderParam.hh>
Public Types
enum  ParamType : uint16_t {
  PARAM_NONE = 0, PARAM_FLOAT = 1, PARAM_INT = 2, PARAM_FLOAT_BUFFER = 3,
  PARAM_INT_BUFFER = 4
 ShaderParam ()
 constructor More...
 ShaderParam (const ShaderParam &_other)
 copy constructor More...
 ~ShaderParam ()
 destructor More...
bool Buffer (std::shared_ptr< void > &_buffer) const
 Get the value of this parameter if it is a buffer. More...
uint32_t Count () const
 Get the element count of this parameter's buffer. More...
void InitializeBuffer (uint32_t _count)
 Set this to be a buffer parameter. More...
ShaderParam & operator= (const ShaderParam &_other)
 Set from another ShaderParam. More...
void operator= (const float _value)
 Set this to be a float parameter. More...
void operator= (const int _value)
 Set this to be an integer parameter. More...
ParamType Type () const
 Get the type of this parameter. More...
void UpdateBuffer (float *_floatBuffer)
 Copy a buffer to this parameter. More...
void UpdateBuffer (int *_intBuffer)
bool Value (float *_value) const
 Get the value of this parameter if it is a float. More...
bool Value (int *_value) const
 Get the value of this parameter if it is an int. More...
◆ ParamType
Enumerator
PARAM_NONE
Type none.
PARAM_FLOAT
Float type parameter.
PARAM_INT
Integer type parameter.
PARAM_FLOAT_BUFFER
Float Buffer type parameter.
PARAM_INT_BUFFER
Int Buffer type parameter.
◆ ShaderParam() [1/2]
constructor
◆ ShaderParam() [2/2]
ShaderParam ( const ShaderParam &  _other)
copy constructor
[in]_otherAnother ShaderParam
◆ ~ShaderParam()
destructor
◆ Buffer()
bool Buffer ( std::shared_ptr< void > &  _buffer) const
[out]_buffervariable the value will be copied to
true if the parameter is the expected type
◆ Count()
uint32_t Count ( ) const
Count of elements in this parameter's buffer
◆ InitializeBuffer()
void InitializeBuffer ( uint32_t  _count)
[in]_countNumber of 32-bit elements in the buffer
◆ operator=() [1/3]
ShaderParam& operator= ( const ShaderParam &  _other)
Reference to this ShaderParam
◆ operator=() [2/3]
void operator= ( const float  _value)
[in]_valueValue to set this parameter to
◆ operator=() [3/3]
void operator= ( const int  _value)
◆ Type()
ParamType Type ( ) const
Type of this parameter
◆ UpdateBuffer() [1/2]
void UpdateBuffer ( float *  _floatBuffer)
[in]_floatBufferSource buffer to copy from
◆ UpdateBuffer() [2/2]
void UpdateBuffer ( int *  _intBuffer)
[in]_intBufferSource buffer to copy from
◆ Value() [1/2]
bool Value ( float *  _value) const
[out]_valuevariable the value will be copied to
◆ Value() [2/2]
bool Value ( int *  _value) const
