Gazebo Sensors
RenderingEvents.hh
16 */
17
18 #ifndef IGNITION_SENSORS_RENDERINGEVENTS_HH_
19 #define IGNITION_SENSORS_RENDERINGEVENTS_HH_
20
21 #include <ignition/common/Event.hh>
22 #include <ignition/common/SuppressWarning.hh>
23
24 // TODO(louise) Remove these pragmas once ign-rendering is disabling the
25 // warnings
26 #ifdef _WIN32
27 #pragma warning(push)
28 #pragma warning(disable: 4251)
29 #endif
30 #include <ignition/rendering/RenderTypes.hh>
31 #ifdef _WIN32
32 #pragma warning(pop)
33 #endif
34
35 #include <ignition/sensors/config.hh>
36 #include <ignition/sensors/rendering/Export.hh>
37
38 namespace ignition
39 {
40  namespace sensors
41  {
42  // Inline bracket to help doxygen filtering.
43  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
44  //
45  class IGNITION_SENSORS_RENDERING_VISIBLE RenderingEvents
46  {
54  public: static ignition::common::ConnectionPtr ConnectSceneChangeCallback(
55  std::function<void(const ignition::rendering::ScenePtr &)>
56  _callback);
57
58  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
61  public: static ignition::common::EventT<
62  void(const ignition::rendering::ScenePtr &)> sceneEvent;
63  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
64  };
65  }
66  }
67 }
68 #endif
Definition: AirPressureSensor.hh:31
Definition: RenderingEvents.hh:45
static ignition::common::EventT< void(const ignition::rendering::ScenePtr &)> sceneEvent
Event that is used to trigger callbacks when the scene is changed.
Definition: RenderingEvents.hh:62
