#include <RenderingEvents.hh>
| static ignition::common::EventT< void(const ignition::rendering::ScenePtr &)> | sceneEvent |
| | Event that is used to trigger callbacks when the scene is changed. More...
◆ ConnectSceneChangeCallback()
| static ignition::common::ConnectionPtr ConnectSceneChangeCallback |
std::function< void(const ignition::rendering::ScenePtr &)> |
_callback | ) |
static |
Set a callback to be called when the scene is changed.
| [in] | _callback | This callback will be called every time the scene is changed. |
- Returns
- A connection pointer that must remain in scope. When the connection pointer falls out of scope, the connection is broken.
◆ sceneEvent
| ignition::common::EventT< void(const ignition::rendering::ScenePtr &)> sceneEvent |
static |
