Gazebo Sensors
SensorFactory.hh
16 */
17 #ifndef IGNITION_SENSORS_SENSORFACTORY_HH_
18 #define IGNITION_SENSORS_SENSORFACTORY_HH_
20 #include <memory>
21 #include <string>
22 #include <type_traits>
23 #include <sdf/sdf.hh>
24
25 #include <ignition/common/Console.hh>
26 #include <ignition/common/SuppressWarning.hh>
27
28 #include <ignition/sensors/config.hh>
29 #include <ignition/sensors/Export.hh>
30
32
33 namespace ignition
34 {
35  namespace sensors
36  {
37  // Inline bracket to help doxygen filtering.
38  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
39  // forward declaration
40  class SensorFactoryPrivate;
41
45  class IGNITION_SENSORS_VISIBLE SensorPlugin
46  {
49  public: virtual Sensor IGN_DEPRECATED(6) * New() = 0;
50  };
51
56  template<class SensorType>
58  {
59  // Documentation inherited
60  public: SensorType IGN_DEPRECATED(6) * New() override
61  {
62  return new SensorType();
63  };
64  };
65
69  // After removing plugin functionality, the sensor factory class doesn't
70  // hold any internal state. Consider converting the functionality in this
71  // class to helper functions.
72  class IGNITION_SENSORS_VISIBLE SensorFactory
73  {
75  public: SensorFactory();
76
78  public: ~SensorFactory();
79
85  public: template<typename SensorType>
86  std::unique_ptr<SensorType> CreateSensor(const sdf::Sensor &_sdf)
87  {
88  auto sensor = std::make_unique<SensorType>();
89
90  if (nullptr == sensor)
91  {
92  ignerr << "Failed to create sensor [" << _sdf.Name()
93  << "] of type[" << _sdf.TypeStr() << "]" << std::endl;
94  return nullptr;
95  }
96
97  if (!sensor->Load(_sdf))
98  {
99  ignerr << "Failed to load sensor [" << _sdf.Name()
100  << "] of type[" << _sdf.TypeStr() << "]" << std::endl;
101  return nullptr;
102  }
103
104  if (!sensor->Init())
105  {
106  ignerr << "Failed to initialize sensor [" << _sdf.Name()
107  << "] of type[" << _sdf.TypeStr() << "]" << std::endl;
108  return nullptr;
109  }
110
111  return sensor;
112  }
113
120  public: template<typename SensorType>
122  {
123  if (nullptr == _sdf)
124  {
125  ignerr << "Failed to create sensor, received null SDF "
126  << "pointer." << std::endl;
127  return nullptr;
128  }
129
130  auto sensor = std::make_unique<SensorType>();
131
132  auto type = _sdf->Get<std::string>("type");
133  auto name = _sdf->Get<std::string>("name");
134
135  if (nullptr == sensor)
136  {
137  ignerr << "Failed to create sensor [" << name
138  << "] of type[" << type << "]" << std::endl;
139  return nullptr;
140  }
141
142  if (!sensor->Load(_sdf))
143  {
144  ignerr << "Failed to load sensor [" << name
145  << "] of type[" << type << "]" << std::endl;
146  return nullptr;
147  }
148
149  if (!sensor->Init())
150  {
151  ignerr << "Failed to initialize sensor [" << name
152  << "] of type[" << type << "]" << std::endl;
153  return nullptr;
154  }
155
156  return sensor;
157  }
158
166  public: std::unique_ptr<Sensor> IGN_DEPRECATED(6) CreateSensor(
167  sdf::ElementPtr _sdf);
168
185  public: std::unique_ptr<Sensor> IGN_DEPRECATED(6) CreateSensor(
186  const sdf::Sensor &_sdf);
187
191  public: void IGN_DEPRECATED(6) AddPluginPaths(const std::string &_path);
192
193  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
195  private: std::unique_ptr<SensorFactoryPrivate> dataPtr;
196  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
197  };
198  }
199  }
200 }
201
202 #endif
Definition: AirPressureSensor.hh:31
STL class.
SensorType * New() override
Instantiate new sensor.
Definition: SensorFactory.hh:60
std::unique_ptr< SensorType > CreateSensor(sdf::ElementPtr _sdf)
Create a sensor from an SDF element with a known sensor type.
Definition: SensorFactory.hh:121
Base sensor plugin interface.
Definition: SensorFactory.hh:45
virtual Sensor * New()=0
T endl(T... args)
STL namespace.
void AddPluginPaths(const std::string &_path)
Add additional path to search for sensor plugins.
Templated class for instantiating sensors of the specified type.
Definition: SensorFactory.hh:57
A factory class for creating sensors This class instantiates sensor objects based on the sensor type ...
Definition: SensorFactory.hh:72
a base sensor class
Definition: Sensor.hh:59
STL class.
std::unique_ptr< SensorType > CreateSensor(const sdf::Sensor &_sdf)
Create a sensor from a SDF DOM object with a known sensor type.
Definition: SensorFactory.hh:86
