a base sensor class More...
#include <Sensor.hh>
| virtual | ~Sensor () |
| destructor More... | |
| void | AddSequence (ignition::msgs::Header *_msg, const std::string &_seqKey="default") |
| Add a sequence number to an ignition::msgs::Header. This function can be called by a sensor that wants to add a sequence number to a sensor message in order to have improved accountability for generated sensor data. More... | |
| FrameId. More... | |
| SensorId | Id () const |
| virtual bool | Init () |
| Initialize values in the sensor This will set the next update time to zero. This is particularly useful if simulation time has jumped backward, for example during a seek backward in a log file. More... | |
| bool | IsActive () const |
| Get whether the sensor is enabled or not. More... | |
| virtual bool | Load (const sdf::Sensor &_sdf) |
| virtual bool | Load (sdf::ElementPtr _sdf) |
| Get name. More... | |
| ignition::math::Pose3d | Pose () const |
| Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is called with the '_force' argument set to true. More... | |
| void | SetPose (const ignition::math::Pose3d &_pose) |
| virtual bool | Update (const std::chrono::steady_clock::duration &_now)=0 |
| Sensor () | |
| constructor More... | |
a base sensor class
This class is a base for all sensor classes. It parses some common SDF elements in the <sensor> tag and is responsible for making sure sensors update at the right time.
◆ Sensor()
protected |
constructor
◆ ~Sensor()
virtual |
destructor
◆ AddSequence()
| void AddSequence | ( | ignition::msgs::Header * | _msg, |
| const std::string & | _seqKey = "default" |
This function will add the following key-value pair to the data field in the provided ignition::msgs::Header msg.
- key: "seq"
- value:
sequence_number
If the "seq" key already exists, then the value will be set without adding another key-value pair.
The sequence_number starts at zero, when a sensor is created, and is incremented by one each time this function is called.
[in,out] _msg The header which will receive the sequence. [in] _seqKey Name of the sequence to use.
◆ EnableMetrics()
| bool EnableMetrics | ( | ) | const |
- Returns
- True if performance metrics are enabled, false otherwise.
◆ FrameId()
| std::string FrameId | ( | ) | const |
FrameId.
- Returns
- FrameId of sensor.
◆ Id()
| SensorId Id | ( | ) | const |
- Returns
- The sensor's ID.
◆ Init()
virtual |
Reimplemented in DepthCameraSensor, ThermalCameraSensor, CameraSensor, ImuSensor, Lidar, GpuLidarSensor, LogicalCameraSensor, SegmentationCameraSensor, RgbdCameraSensor, ForceTorqueSensor, NavSatSensor, BoundingBoxCameraSensor, MagnetometerSensor, AirPressureSensor, and AltimeterSensor.
◆ IsActive()
| bool IsActive | ( | ) | const |
- Returns
- True if the sensor is active, false otherwise.
- See also
- SetActive
◆ Load() [1/2]
virtual |
[in] _sdf SDF <sensor> or <plugin> inside of <sensor>
- Returns
- true if loading was successful
Reimplemented in DepthCameraSensor, ThermalCameraSensor, CameraSensor, GpuLidarSensor, ImuSensor, Lidar, SegmentationCameraSensor, RgbdCameraSensor, ForceTorqueSensor, NavSatSensor, BoundingBoxCameraSensor, MagnetometerSensor, AirPressureSensor, and AltimeterSensor.
◆ Load() [2/2]
virtual |
- Returns
Reimplemented in DepthCameraSensor, ThermalCameraSensor, CameraSensor, GpuLidarSensor, ImuSensor, Lidar, LogicalCameraSensor, SegmentationCameraSensor, RgbdCameraSensor, ForceTorqueSensor, NavSatSensor, BoundingBoxCameraSensor, MagnetometerSensor, AirPressureSensor, and AltimeterSensor.
◆ Name()
| std::string Name | ( | ) | const |
Get name.
- Returns
- Name of sensor.
◆ NextDataUpdateTime()
| std::chrono::steady_clock::duration NextDataUpdateTime | ( | ) | const |
◆ Parent()
| std::string Parent | ( | ) | const |
- Returns
- Parent link of sensor.
◆ Pose()
| ignition::math::Pose3d Pose | ( | ) | const |
- Returns
- Current pose of the sensor.
◆ PublishMetrics()
| void PublishMetrics | ( | const std::chrono::duration< double > & | _now | ) |
[in] _now Current time.
◆ SDF()
| sdf::ElementPtr SDF | ( | ) | const |
- Returns
- Pointer to an SDF element that contains initialization information for this sensor.
◆ SetActive()
| void SetActive | ( | bool | _active | ) |
[in] _active True to set the sensor to be active, false to disable the sensor.
- See also
- IsActive
◆ SetEnableMetrics()
| void SetEnableMetrics | ( | bool | _enableMetrics | ) |
[in] _enableMetrics True to enable.
◆ SetFrameId()
| void SetFrameId | ( | const std::string & | _frameId | ) |
[in] _frameId Frame ID of the sensor
◆ SetParent()
virtual |
Reimplemented in Lidar.
◆ SetPose()
| void SetPose | ( | const ignition::math::Pose3d & | _pose | ) |
◆ SetTopic()
| bool SetTopic | ( | const std::string & | _topic | ) |
[in] _topic Topic sensor publishes data to.
- Returns
- True if a valid topic was set.
◆ SetUpdateRate()
| void SetUpdateRate | ( | const double | _hz | ) |
[in] _hz Update rate of sensor in Hertz.
◆ Topic()
| std::string Topic | ( | ) | const |
- Returns
- Topic sensor publishes data to
◆ Update() [1/2]
pure virtual |
[in] _now The current time
- Returns
- See also
- SetUpdateRate()
Implemented in DepthCameraSensor, ThermalCameraSensor, CameraSensor, ImuSensor, LogicalCameraSensor, SegmentationCameraSensor, RgbdCameraSensor, ForceTorqueSensor, NavSatSensor, BoundingBoxCameraSensor, GpuLidarSensor, MagnetometerSensor, AirPressureSensor, AltimeterSensor, and Lidar.
◆ Update() [2/2]
| bool Update | ( | const std::chrono::steady_clock::duration & | _now, |
| const bool | _force | ||
Update the sensor.
[in] _now The current time [in] _force Force the update to happen even if it's not time
- Returns
- True if the update was triggered (_force was true or _now >= next_update_time) and the sensor's bool Sensor::Update(std::chrono::steady_clock::time_point) function returned true. False otherwise.
- Remarks
- If forced the NextUpdateTime() will be unchanged.
◆ UpdateRate()
| double UpdateRate | ( | ) | const |
The update rate is the number of times per second a sensor should generate and output data.
- Returns
- _hz update rate of sensor.
