Gazebo Sensors
Sensor.hh
2  * Copyright (C) 2017 Open Source Robotics Foundation
16 */
17 #ifndef IGNITION_SENSORS_SENSOR_HH_
18 #define IGNITION_SENSORS_SENSOR_HH_
20 #ifdef _WIN32
21 #pragma warning(push)
22 #pragma warning(disable: 4005)
23 #pragma warning(disable: 4251)
24 #endif
25 #include <ignition/msgs/header.pb.h>
26 #ifdef _WIN32
27 #pragma warning(pop)
28 #endif
29
30 #include <chrono>
31 #include <memory>
32 #include <string>
33
34 #include <ignition/common/SuppressWarning.hh>
35 #include <ignition/math/Pose3.hh>
36 #include <ignition/sensors/config.hh>
37 #include <ignition/sensors/Export.hh>
38 #include <sdf/sdf.hh>
39
40 namespace ignition
41 {
42  namespace sensors
43  {
44  // Inline bracket to help doxygen filtering.
45  inline namespace IGNITION_SENSORS_VERSION_NAMESPACE {
46  //
49  const SensorId NO_SENSOR = 0;
50
52  class SensorPrivate;
53
59  class IGNITION_SENSORS_VISIBLE Sensor
60  {
62  protected: Sensor();
63
65  public: virtual ~Sensor();
66
70  public: virtual bool Load(const sdf::Sensor &_sdf);
71
75  public: virtual bool Load(sdf::ElementPtr _sdf);
76
81  public: virtual bool Init();
82
96  public: virtual bool Update(
97  const std::chrono::steady_clock::duration &_now) = 0;
98
100  public: std::chrono::steady_clock::duration NextDataUpdateTime() const;
101
115  public: bool Update(
116  const std::chrono::steady_clock::duration &_now, const bool _force);
117
123  public: double UpdateRate() const;
124
129  public: void SetUpdateRate(const double _hz);
130
133  public: ignition::math::Pose3d Pose() const;
134
136  public: void SetPose(const ignition::math::Pose3d &_pose);
137
139  public: virtual void SetParent(const std::string &_parent);
140
143  public: std::string Name() const;
144
147  public: std::string FrameId() const;
148
151  public: void SetFrameId(const std::string &_frameId);
152
155  public: std::string Topic() const;
156
160  public: bool SetTopic(const std::string &_topic);
161
164  public: bool EnableMetrics() const;
165
168  public: void SetEnableMetrics(bool _enableMetrics);
169
172  public: std::string Parent() const;
173
176  public: SensorId Id() const;
177
181  public: sdf::ElementPtr SDF() const;
182
201  public: void AddSequence(ignition::msgs::Header *_msg,
202  const std::string &_seqKey = "default");
203
207  public: void PublishMetrics(
208  const std::chrono::duration<double> &_now);
209
213  public: bool IsActive() const;
214
221  public: void SetActive(bool _active);
222
223  IGN_COMMON_WARN_IGNORE__DLL_INTERFACE_MISSING
226  private: std::unique_ptr<SensorPrivate> dataPtr;
227  IGN_COMMON_WARN_RESUME__DLL_INTERFACE_MISSING
228  };
229  }
230  }
231 }
232 #endif
Definition: AirPressureSensor.hh:31
STL class.
Enable or disable the sensor. Disabled sensors will not generate or publish data unless Update is cal...
FrameId.
void PublishMetrics(const std::chrono::duration< double > &_now)
Set the parent of the sensor.
virtual bool Update(const std::chrono::steady_clock::duration &_now)=0
void AddSequence(ignition::msgs::Header *_msg, const std::string &_seqKey="default")
Add a sequence number to an ignition::msgs::Header. This function can be called by a sensor that want...
Set Frame ID of the sensor.
Definition: Sensor.hh:49
virtual bool Init()
Initialize values in the sensor This will set the next update time to zero. This is particularly usef...
Get the current pose.
Get name.
Set the update rate of the sensor. An update rate of zero means that the sensor is updated every cycl...
a base sensor class
Definition: Sensor.hh:59
SensorId Id() const
Get the sensor's ID.
virtual ~Sensor()
destructor
