Ignition Sensors
AirPressureSensor Class Reference
#include <AirPressureSensor.hh>
 AirPressureSensor ()
 constructor More...
virtual ~AirPressureSensor ()
 destructor More...
virtual bool Init () override
double ReferenceAltitude () const
 Get the vertical reference altitude. More...
void SetReferenceAltitude (double _reference)
 Set the reference altitude. More...
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 Sensor ()
 constructor More...
A sensor that reports air pressure readings.
◆ AirPressureSensor()
constructor
◆ ~AirPressureSensor()
virtual ~AirPressureSensor ( )
destructor
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
◆ ReferenceAltitude()
double ReferenceAltitude ( ) const
Verical reference position in meters
◆ SetReferenceAltitude()
void SetReferenceAltitude ( double  _reference)
[in]_refVerical reference position in meters
[in]_nowThe current time
Implements Sensor.
