Ignition Sensors
AltimeterSensor Class Reference
#include <AltimeterSensor.hh>
 AltimeterSensor ()
 constructor More...
virtual ~AltimeterSensor ()
 destructor More...
virtual bool Init () override
void SetPosition (double _pos)
 Set the current z position of the altimeter. More...
void SetVerticalReference (double _reference)
 Set the vertical reference position of the altimeter. More...
void SetVerticalVelocity (double _vel)
 Set the vertical velocity of the altimeter. More...
double VerticalPosition () const
 Get the vertical position of the altimeter relative to the reference position. More...
double VerticalReference () const
 Get the vertical reference position of the altimeter. More...
double VerticalVelocity () const
 Get the vertical velocity of the altimeter. More...
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 Sensor ()
 constructor More...
An altimeter sensor that reports vertical position and velocity readings over ign transport
◆ AltimeterSensor()
constructor
◆ ~AltimeterSensor()
virtual ~AltimeterSensor ( )
destructor
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
◆ SetPosition()
void SetPosition ( double  _pos)
[in]_posZ position in meters
◆ SetVerticalReference()
void SetVerticalReference ( double  _reference)
[in]_refVerical reference position in meters
◆ SetVerticalVelocity()
void SetVerticalVelocity ( double  _vel)
[in]_velVertical velocity in meters per second
[in]_nowThe current time
Implements Sensor.
◆ VerticalPosition()
double VerticalPosition ( ) const
Vertical position relative to referene position
◆ VerticalReference()
double VerticalReference ( ) const
◆ VerticalVelocity()
double VerticalVelocity ( ) const
