Ignition Sensors
ImuSensor Class Reference
Imu Sensor Class. More...
#include <ImuSensor.hh>
 ImuSensor ()
 constructor More...
virtual ~ImuSensor ()
 destructor More...
math::Vector3d AngularVelocity () const
 Get the angular velocity of the imu. More...
math::Vector3d Gravity () const
 Get the gravity vector. More...
virtual bool Init () override
math::Vector3d LinearAcceleration () const
 Get the linear acceleration of the imu. More...
math::Quaterniond Orientation () const
 Get the orienation of the imu with respect to reference frame. More...
bool OrientationEnabled () const
 Get whether or not orientation is enabled. More...
math::Quaterniond OrientationReference () const
 Get the world orienation reference of the imu. More...
void SetAngularVelocity (const math::Vector3d &_angularVel)
 Set the angular velocity of the imu. More...
void SetGravity (const math::Vector3d &_gravity)
 Set the gravity vector. More...
void SetLinearAcceleration (const math::Vector3d &_linearAcc)
 Set the linear acceleration of the imu. More...
void SetOrientationEnabled (bool _enabled)
 Set whether to output orientation. Not all imu's generate orientation values as they use filters to produce orientation estimates. More...
void SetOrientationReference (const math::Quaterniond &_orient)
 Set the orientation reference, i.e. initial imu orientation. Imu orientation data generated will be relative to this reference frame. More...
 Set the world pose of the imu. More...
 Get the world pose of the imu. More...
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 Sensor ()
 constructor More...
Imu Sensor Class.
An imu sensor that reports linear acceleration, angular velocity, and orientation
◆ ImuSensor()
ImuSensor ( )
constructor
◆ ~ImuSensor()
virtual ~ImuSensor ( )
destructor
◆ AngularVelocity()
math::Vector3d AngularVelocity ( ) const
Angular velocity of the imu in body frame, expressed in radians per second.
◆ Gravity()
math::Vector3d Gravity ( ) const
Gravity vectory in meters per second squared.
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ LinearAcceleration()
math::Vector3d LinearAcceleration ( ) const
Linear acceleration of the imu in local frame, expressed in meters per second squared.
◆ Load() [1/2]
◆ Load() [2/2]
◆ Orientation()
math::Quaterniond Orientation ( ) const
Orientation in reference frame. If orientation is not enabled, this will return the last computed orientation before orientation is disabled or identity Quaternion if orientation has never been enabled.
◆ OrientationEnabled()
bool OrientationEnabled ( ) const
True if orientation is enabled, false otherwise.
◆ OrientationReference()
math::Quaterniond OrientationReference ( ) const
Orientation reference in world frame
◆ SetAngularVelocity()
void SetAngularVelocity ( const math::Vector3d &  _angularVel)
[in]_angularVelAngular velocity of the imu in body frame expressed in radians per second
◆ SetGravity()
void SetGravity ( const math::Vector3d &  _gravity)
[in]_gravitygravity vector in meters per second squared.
◆ SetLinearAcceleration()
void SetLinearAcceleration ( const math::Vector3d &  _linearAcc)
[in]_linearAccLinear accceleration of the imu in body frame expressed in meters per second squared.
◆ SetOrientationEnabled()
void SetOrientationEnabled ( bool  _enabled)
[in]_enabledTrue to publish orientation data, false to leave the message field empty.
◆ SetOrientationReference()
void SetOrientationReference ( const math::Quaterniond &  _orient)
[in]_orientationReference orientation
◆ SetWorldPose()
[in]_posePose in world frame
[in]_nowThe current time
Implements Sensor.
◆ WorldPose()
Pose in world frame.
