Ignition Sensors
MagnetometerSensor Class Reference
#include <MagnetometerSensor.hh>
 MagnetometerSensor ()
 constructor More...
virtual ~MagnetometerSensor ()
 destructor More...
virtual bool Init () override
math::Vector3d MagneticField () const
 Get the magnetic field vector in body frame. More...
void SetWorldMagneticField (const math::Vector3d &_field)
 Set the magnetic field vector in world frame. More...
 Set the world pose of the sensor. More...
math::Vector3d WorldMagneticField () const
 Get the magnetic field vector in world frame. More...
 Get the world pose of the sensor. More...
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 Sensor ()
 constructor More...
A magnetometer reports the magnetic field vector
◆ MagnetometerSensor()
constructor
◆ ~MagnetometerSensor()
virtual ~MagnetometerSensor ( )
destructor
virtual bool Init ( )
True on success
Reimplemented from Sensor.
◆ Load() [1/2]
◆ Load() [2/2]
◆ MagneticField()
math::Vector3d MagneticField ( ) const
Magnetic field vector in body frame
◆ SetWorldMagneticField()
void SetWorldMagneticField ( const math::Vector3d &  _field)
[in]_fieldMagnetic field vector in world frame.
◆ SetWorldPose()
[in]_posePose in world frame
[in]_nowThe current time
Implements Sensor.
◆ WorldMagneticField()
math::Vector3d WorldMagneticField ( ) const
◆ WorldPose()
Pose in world frame.
