Ignition Sensors
NoiseFactory Class Reference
#include <ignition/sensors/Noise.hh>
static NoisePtr NewNoiseModel (sdf::ElementPtr _sdf, const std::string &_sensorType="")
 Load a noise model based on the input sdf parameters and sensor type. More...
static NoisePtr NewNoiseModel (const sdf::Noise &_sdf, const std::string &_sensorType="")
◆ NewNoiseModel() [1/2]
static NoisePtr NewNoiseModel ( sdf::ElementPtr  _sdf,
const std::string _sensorType = ""
static
[in]_sdfNoise sdf parameters.
[in]_sensorTypeType of sensor. This is currently used to distinguish between image and non image sensors in order to create the appropriate noise model.
Pointer to the noise model created.
◆ NewNoiseModel() [2/2]
static NoisePtr NewNoiseModel ( const sdf::Noise &  _sdf,
static
