Ignition Sensors
#include <RenderingEvents.hh>
static ignition::common::ConnectionPtr ConnectSceneChangeCallback (std::function< void(const ignition::rendering::ScenePtr &)> _callback)
 Set a callback to be called when the scene is changed. More...
Static Public Attributes
static ignition::common::EventT< void(const ignition::rendering::ScenePtr &)> sceneEvent
 Event that is used to trigger callbacks when the scene is changed. More...
◆ ConnectSceneChangeCallback()
static ignition::common::ConnectionPtr ConnectSceneChangeCallback ( std::function< void(const ignition::rendering::ScenePtr &)>  _callback)
static
[in]_callbackThis callback will be called every time the scene is changed.
Remarks
◆ sceneEvent
static
