Ignition Sensors
#include <RenderingSensor.hh>
virtual ~RenderingSensor ()
 destructor More...
void Render ()
 destructor More...
bool EnableMetrics () const
SensorId Id () const
 Get the sensor's ID. More...
virtual bool Init ()
 Initialize values in the sensor This will set the next update time to zero. This is particularly useful if simulation time has jumped backward, for example during a seek backward in a log file. More...
virtual bool Load (sdf::ElementPtr _sdf)
std::string Name () const
 Get name. More...
std::string Parent () const
 Get the current pose. More...
sdf::ElementPtr SDF () const
std::string Topic () const
 Update the sensor. More...
double UpdateRate () const
 RenderingSensor ()
 constructor More...
 Sensor ()
 constructor More...
This class is a base for all rendering sensor classes. It provides interface to ignition rendering objects
◆ RenderingSensor()
RenderingSensor ( )
constructor
◆ ~RenderingSensor()
virtual ~RenderingSensor ( )
destructor
◆ AddSensor()
void AddSensor ( rendering::SensorPtr  _sensor)
[in]_sensorSensor to add.
◆ ManualSceneUpdate()
bool ManualSceneUpdate ( ) const
True if manual scene graph update is enabled, false otherwise
◆ Render()
void Render ( )
◆ Scene()
rendering::ScenePtr Scene ( ) const
◆ SetManualSceneUpdate()
void SetManualSceneUpdate ( bool  _manual)
[in]_manualTrue to enable manual scene graph update
◆ SetScene()
virtual void SetScene ( rendering::ScenePtr  _scene)
