BaseMarker.hh
16 */
17 #ifndef IGNITION_RENDERING_BASEMARKER_HH_
18 #define IGNITION_RENDERING_BASEMARKER_HH_
21
25
26 namespace ignition
27 {
28  namespace rendering
29  {
30  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  template <class T>
33  class BaseMarker :
34  public virtual Marker,
35  public virtual T
36  {
38  protected: BaseMarker();
39
41  public: virtual ~BaseMarker();
42
44  public: virtual void PreRender() override;
45
47  public: virtual void Destroy() override;
48
49  // Documentation inherited
50  public: virtual void SetLifetime(const
51  std::chrono::steady_clock::duration &_lifetime) override;
52
53  // Documentation inherited
54  public: virtual std::chrono::steady_clock::duration Lifetime()
55  const override;
56
57  // Documentation inherited
58  public: virtual void SetType(const MarkerType _markerType) override;
59
60  // Documentation inherited
61  public: virtual MarkerType Type() const override;
62
63  // Documentation inherited
64  public: virtual void SetLayer(int32_t _layer) override;
65
66  // Documentation inherited
67  public: virtual int32_t Layer() const override;
68
69  // Documentation inherited
70  public: virtual void ClearPoints() override;
71
72  // Documentation inherited
73  public: virtual void AddPoint(double _x,
74  double _y, double _z,
75  const ignition::math::Color &_color) override;
76
77  // Documentation inherited
78  public: virtual void AddPoint(const ignition::math::Vector3d &_pt,
79  const ignition::math::Color &_color) override;
80
81  // Documentation inherited
82  public: virtual void SetPoint(unsigned int _index,
83  const ignition::math::Vector3d &_value) override;
84
87  protected: std::chrono::steady_clock::duration lifetime =
88  std::chrono::steady_clock::duration::zero();
90
92  protected: int32_t layer = 0;
93
95  protected: bool markerDirty = false;
96
98  protected: MarkerType markerType =
100  };
101
103  // BaseMarker
105  template <class T>
107  {
108  }
109
111  template <class T>
113  {
114  }
115
117  template <class T>
119  const std::chrono::steady_clock::duration &_lifetime)
120  {
121  this->lifetime = _lifetime;
122  this->markerDirty = true;
123  }
124
126  template <class T>
127  std::chrono::steady_clock::duration BaseMarker<T>::Lifetime() const
128  {
129  return this->lifetime;
130  }
131
133  template <class T>
134  void BaseMarker<T>::SetLayer(int32_t _layer)
135  {
136  this->layer = _layer;
137  this->markerDirty = true;
138  }
139
141  template <class T>
142  int32_t BaseMarker<T>::Layer() const
143  {
144  return this->layer;
145  }
146
148  template <class T>
149  void BaseMarker<T>::SetType(const MarkerType _markerType)
150  {
151  this->markerType = _markerType;
152  this->markerDirty = true;
153  }
154
156  template <class T>
158  {
159  return this->markerType;
160  }
161
163  template <class T>
165  {
166  T::PreRender();
167  }
168
170  template <class T>
172  {
173  T::Destroy();
174  }
175
177  template <class T>
179  {
180  // no op
181  }
182
184  template <class T>
186  const ignition::math::Color &)
187  {
188  // no op
189  }
190
192  template <class T>
193  void BaseMarker<T>::AddPoint(double _x, double _y, double _z,
194  const ignition::math::Color &_color)
195  {
196  this->AddPoint(ignition::math::Vector3d(_x, _y, _z), _color);
197  }
198
200  template <class T>
201  void BaseMarker<T>::SetPoint(unsigned int,
202  const ignition::math::Vector3d &)
203  {
204  // no op
205  }
206  }
207  }
208 }
209 #endif
virtual std::chrono::steady_clock::duration Lifetime() const override
Get the lifetime of this Marker.
Definition: BaseMarker.hh:127
virtual void AddPoint(double _x, double _y, double _z, const ignition::math::Color &_color) override
Add a point with its respective color to the marker.
Definition: BaseMarker.hh:193
@ MT_NONE
No type.
Definition: Marker.hh:38
Clear the points of the marker, if applicable.
Definition: BaseMarker.hh:178
Life time of a marker.
Definition: BaseMarker.hh:87
int32_t layer
Layer at which the marker will reside.
Definition: BaseMarker.hh:92
bool markerDirty
Flag to indicate if marker needs to be updated.
Definition: BaseMarker.hh:95
Definition: BaseMarker.hh:112
Get the render type of this Marker.
Definition: BaseMarker.hh:157
Destroy function.
Definition: BaseMarker.hh:171
A marker geometry class. The marker's visual appearance is based on the marker type specified.
Definition: Marker.hh:74
BaseMarker()
Definition: BaseMarker.hh:106
Base implementation of a Marker geometry.
Definition: BaseMarker.hh:33
MarkerType
Enum for marker types.
Definition: Marker.hh:35
Set the layer of this Marker.
Definition: BaseMarker.hh:134
virtual void SetPoint(unsigned int _index, const ignition::math::Vector3d &_value) override
Set an existing point's vector.
Definition: BaseMarker.hh:201
PreRender function.
Definition: BaseMarker.hh:164
virtual void SetLifetime(const std::chrono::steady_clock::duration &_lifetime) override
Set the lifetime of this Marker.
Definition: BaseMarker.hh:118
Set the render type of this Marker.
Definition: BaseMarker.hh:149
Get the layer of this Marker.
Definition: BaseMarker.hh:142
Marker type.
Definition: BaseMarker.hh:98
