#include <BaseMarker.hh>
virtual ~BaseMarker ()
virtual void AddPoint (const ignition::math::Vector3d &_pt, const ignition::math::Color &_color) override
virtual void AddPoint (double _x, double _y, double _z, const ignition::math::Color &_color) override
 Destroy function. More...
 PreRender function. More...
virtual void SetPoint (unsigned int _index, const ignition::math::Vector3d &_value) override
virtual ~Marker ()
 BaseMarker ()
 Marker ()
int32_t layer = 0
bool markerDirty = false
MarkerType markerType
 Marker type. More...
template<class T>
class ignition::rendering::BaseMarker< T >
◆ BaseMarker()
BaseMarker
◆ ~BaseMarker()
~BaseMarker
◆ AddPoint() [1/2]
void AddPoint ( const ignition::math::Vector3d &  _pt,
Implements Marker.
Reimplemented in OgreMarker, and Ogre2Marker.
◆ AddPoint() [2/2]
void AddPoint ( double  _x,
double  _y,
double  _z,
[in]_xX coordinate
[in]_yY coordinate
[in]_zZ coordinate
Implements Marker.
◆ ClearPoints()
void ClearPoints ( )
Implements Marker.
void Destroy
Destroy function.
◆ Layer()
int32_t Layer ( ) const
The layer of the marker
Implements Marker.
◆ Lifetime()
std::chrono::steady_clock::duration Lifetime ( ) const
Implements Marker.
void PreRender
PreRender function.
◆ SetLayer()
void SetLayer ( int32_t  _layer)
Implements Marker.
◆ SetLifetime()
void SetLifetime ( const std::chrono::steady_clock::duration &  _lifetime)
Implements Marker.
◆ SetPoint()
Implements Marker.
◆ SetType()
void SetType ( const MarkerType  _markerType)
Implements Marker.
◆ Type()
MarkerType Type ( ) const
The render type of the marker
Implements Marker.
◆ layer
int32_t layer = 0
◆ lifetime
Initial value:
std::chrono::steady_clock::duration::zero()
◆ markerDirty
◆ markerType
Initial value:
Marker type.
@ MT_NONE
No type.
Definition: Marker.hh:38
