RenderTypes.hh
17 #ifndef IGNITION_RENDERING_RENDERTYPES_HH_
18 #define IGNITION_RENDERING_RENDERTYPES_HH_
20 #include <memory>
21 #include <ignition/rendering/config.hh>
22
23
26 #define IGN_VISIBILITY_ALL 0x0FFFFFFF
27
30 #define IGN_VISIBILITY_SELECTION 0x10000000
31
34 #define IGN_VISIBILITY_GUI 0x00000001
35
38 #define IGN_VISIBILITY_SELECTABLE 0x00000002
39
40 namespace ignition
41 {
42  namespace rendering
43  {
44  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
45  //
46  template <class T>
48
49  class ArrowVisual;
50  class AxisVisual;
51  class Camera;
52  class DepthCamera;
53  class DirectionalLight;
54  class GaussianNoisePass;
55  class Geometry;
56  class GizmoVisual;
57  class GpuRays;
58  class Grid;
59  class JointVisual;
60  class Image;
61  class Light;
62  class Material;
63  class Marker;
64  class Mesh;
65  class Node;
66  class Object;
67  class ObjectFactory;
68  class PointLight;
69  class RayQuery;
70  class RenderEngine;
71  class RenderPass;
72  class RenderPassSystem;
73  class RenderTarget;
74  class RenderTexture;
75  class RenderWindow;
76  class Scene;
77  class Sensor;
78  class ShaderParams;
79  class SpotLight;
80  class SubMesh;
81  class Text;
82  class ThermalCamera;
83  class Visual;
84
88
92
96
100
104
108
112
116
120
124
128
132
136
140
144
148
152
156
160
164
168
172
176
180
184
188
195
199
202
206
210
214
218
222
226
230
234
238
242
246
250
254
258
262
266
270
274
278
282
286
290
294
298
302
306
310
314
318
322
326
329
333
337
341
345  }
346  }
347 }
348 #endif
shared_ptr< Object > ObjectPtr
Shared pointer to Object.
Definition: RenderTypes.hh:159
shared_ptr< const Material > ConstMaterialPtr
Definition: RenderTypes.hh:273
shared_ptr< const Sensor > ConstSensorPtr
Definition: RenderTypes.hh:325
Represents a billboard text geometry that is always facing the camera.
Definition: Text.hh:62
shared_ptr< RayQuery > RayQueryPtr
Shared pointer to RayQuery.
Definition: RenderTypes.hh:171
shared_ptr< SubMesh > SubMeshPtr
Shared pointer to SubMesh.
Definition: RenderTypes.hh:209
shared_ptr< const PointLight > ConstPointLightPtr
Definition: RenderTypes.hh:293
shared_ptr< const Image > ConstImagePtr
Definition: RenderTypes.hh:265
shared_ptr< Geometry > GeometryPtr
Shared pointer to Geometry.
Definition: RenderTypes.hh:119
Definition: Node.hh:37
Definition: Sensor.hh:32
shared_ptr< GpuRays > GpuRaysPtr
Shared pointer to GpuRays.
Definition: RenderTypes.hh:107
STL class.
shared_ptr< const ThermalCamera > ConstThermalCameraPtr
Definition: RenderTypes.hh:237
shared_ptr< const ObjectFactory > ConstObjectFactoryPtr
Definition: RenderTypes.hh:289
Represents a off-screen render-texture to which cameras can render images.
Definition: RenderTarget.hh:103
shared_ptr< const JointVisual > ConstJointVisualPtr
Definition: RenderTypes.hh:261
shared_ptr< const AxisVisual > ConstAxisVisualPtr
Definition: RenderTypes.hh:225
shared_ptr< const Node > ConstNodePtr
Definition: RenderTypes.hh:281
Definition: DepthCamera.hh:34
A render pass that applies Gaussian noise to the render target.
Definition: GaussianNoisePass.hh:35
Represents a spotlight.
Definition: Light.hh:145
shared_ptr< Light > LightPtr
Shared pointer to Light.
Definition: RenderTypes.hh:139
Represents a on-screen render-window to which cameras can render images.
Definition: RenderTarget.hh:119
shared_ptr< const Mesh > ConstMeshPtr
Definition: RenderTypes.hh:277
Definition: Image.hh:36
shared_ptr< SpotLight > SpotLightPtr
Shared pointer to SpotLight.
Definition: RenderTypes.hh:205
shared_ptr< const Scene > ConstScenePtr
Definition: RenderTypes.hh:321
shared_ptr< const RenderPass > ConstRenderPassPtr
Definition: RenderTypes.hh:301
shared_ptr< const Geometry > ConstGeometryPtr
Definition: RenderTypes.hh:253
shared_ptr< JointVisual > JointVisualPtr
Shared pointer to JointVisual.
Definition: RenderTypes.hh:131
Definition: Camera.hh:40
shared_ptr< Grid > GridPtr
Shared pointer to Grid.
Definition: RenderTypes.hh:127
shared_ptr< const RenderWindow > ConstRenderWindowPtr
Definition: RenderTypes.hh:317
shared_ptr< const RenderTarget > ConstRenderTargetPtr
Definition: RenderTypes.hh:309
shared_ptr< Sensor > SensorPtr
Shared pointer to Sensor.
Definition: RenderTypes.hh:198
Definition: Scene.hh:48
shared_ptr< GaussianNoisePass > GaussianNoisePassPtr
Shared pointer to GaussianNoisePass.
Definition: RenderTypes.hh:115
shared_ptr< RenderPassSystem > RenderPassSystemPtr
Shared pointer to RenderPassSystem.
Definition: RenderTypes.hh:179
a map that holds params to be passed to a shader
Definition: ShaderParams.hh:38
shared_ptr< const Object > ConstObjectPtr
Definition: RenderTypes.hh:285
shared_ptr< const GpuRays > ConstGpuRaysPtr
Definition: RenderTypes.hh:241
shared_ptr< const ShaderParams > ConstShaderParamsPtr
Shared pointer to const ShaderParams.
Definition: RenderTypes.hh:328
Represents a collection of mesh geometries.
Definition: Mesh.hh:35
shared_ptr< Mesh > MeshPtr
Shared pointer to Mesh.
Definition: RenderTypes.hh:151
shared_ptr< const SpotLight > ConstSpotLightPtr
Definition: RenderTypes.hh:332
shared_ptr< RenderTexture > RenderTexturePtr
Shared pointer to RenderTexture.
Definition: RenderTypes.hh:187
shared_ptr< RenderTarget > RenderTargetPtr
Shared pointer to RenderTarget.
Definition: RenderTypes.hh:183
shared_ptr< const GizmoVisual > ConstGizmoVisualPtr
Definition: RenderTypes.hh:257
shared_ptr< Image > ImagePtr
Shared pointer to Image.
Definition: RenderTypes.hh:135
Represents a single mesh geometry.
Definition: Mesh.hh:91
Definition: RenderTarget.hh:37
Definition: Visual.hh:36
shared_ptr< const Camera > ConstCameraPtr
Definition: RenderTypes.hh:229
shared_ptr< const Text > ConstTextPtr
Definition: RenderTypes.hh:340
Represents a axis composite visual.
Definition: AxisVisual.hh:31
shared_ptr< const DirectionalLight > ConstDirectionalLightPtr
Definition: RenderTypes.hh:245
A Ray Query class used for computing ray object intersections.
Definition: RayQuery.hh:63
Generate depth ray data.
Definition: GpuRays.hh:37
Represents a infinite directional light.
Definition: Light.hh:113
shared_ptr< const RenderPassSystem > ConstRenderPassSystemPtr
Definition: RenderTypes.hh:305
shared_ptr< const GaussianNoisePass > ConstGaussianNoisePass
Shared pointer to const GaussianNoisePass.
Definition: RenderTypes.hh:249
shared_ptr< GizmoVisual > GizmoVisualPtr
Shared pointer to GizmoVisual.
Definition: RenderTypes.hh:123
shared_ptr< const Light > ConstLightPtr
Definition: RenderTypes.hh:269
shared_ptr< ThermalCamera > ThermalCameraPtr
Shared pointer to ThermalCamera.
Definition: RenderTypes.hh:103
Shared pointer to Visual.
Definition: RenderTypes.hh:217
shared_ptr< ArrowVisual > ArrowVisualPtr
Shared pointer to ArrowVisual.
Definition: RenderTypes.hh:87
Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the gri...
Definition: Grid.hh:34
Thermal camera that produces temperature data. An object's temperature can be set through the Visual ...
Definition: ThermalCamera.hh:40
A render pass can be added to a camera to affect how the scene is rendered. It can be used to add pos...
Definition: RenderPass.hh:34
A marker geometry class. The marker's visual appearance is based on the marker type specified.
Definition: Marker.hh:74
shared_ptr< Camera > CameraPtr
Shared pointer to Camera.
Definition: RenderTypes.hh:95
Represents a point light.
Definition: Light.hh:136
Definition: Object.hh:34
Represents a light source in the scene graph.
Definition: Light.hh:32
shared_ptr< Text > TextPtr
Shared pointer to Text.
Definition: RenderTypes.hh:213
shared_ptr< Node > NodePtr
Shared pointer to Node.
Definition: RenderTypes.hh:155
shared_ptr< const DepthCamera > ConstDepthCameraPtr
Definition: RenderTypes.hh:233
shared_ptr< const Visual > ConstVisualPtr
Definition: RenderTypes.hh:344
shared_ptr< RenderPass > RenderPassPtr
Shared pointer to RenderPass.
Definition: RenderTypes.hh:175
shared_ptr< RenderWindow > RenderWindowPtr
Shared pointer to RenderWindow.
Definition: RenderTypes.hh:191
shared_ptr< PointLight > PointLightPtr
Shared pointer to PointLight.
Definition: RenderTypes.hh:167
shared_ptr< Scene > ScenePtr
Shared pointer to Scene.
Definition: RenderTypes.hh:194
Definition: RenderEngine.hh:36
shared_ptr< const SubMesh > ConstSubMeshPtr
Definition: RenderTypes.hh:336
shared_ptr< const RenderTexture > ConstRenderTexturePtr
Definition: RenderTypes.hh:313
A class for creating and managing render passes.
Definition: RenderPassSystem.hh:56
shared_ptr< ObjectFactory > ObjectFactoryPtr
Shared pointer to ObjectFactory.
Definition: RenderTypes.hh:163
shared_ptr< Material > MaterialPtr
Shared pointer to Material.
Definition: RenderTypes.hh:143
Definition: Material.hh:47
shared_ptr< const RayQuery > ConstRayQueryPtr
Definition: RenderTypes.hh:297
A gizmo that contains rotate, translate, and scale visuals.
Definition: GizmoVisual.hh:34
shared_ptr< DirectionalLight > DirectionalLightPtr
Shared pointer to DirectionalLight.
Definition: RenderTypes.hh:111
shared_ptr< Marker > MarkerPtr
Shared pointer to Marker.
Definition: RenderTypes.hh:147
shared_ptr< const ArrowVisual > ConstArrowVisualPtr
Definition: RenderTypes.hh:221
shared_ptr< DepthCamera > DepthCameraPtr
Shared pointer to DepthCamera.
Definition: RenderTypes.hh:99
Represents a geometric shape to be rendered.
Definition: Geometry.hh:34
shared_ptr< AxisVisual > AxisVisualPtr
Shared pointer to AxisVisual.
Definition: RenderTypes.hh:91
shared_ptr< ShaderParams > ShaderParamsPtr
Shared pointer to ShaderParams.
Definition: RenderTypes.hh:201
Represents a arrow composite visual.
Definition: ArrowVisual.hh:31
