Gpu Rays used to render range data into an image buffer The ogre2 implementation takes a 2 pass process to generate the final range data. 1st Pass: Creates a cubemap of range data. The cubemap is created from six cameras looking in all directions. Depending on the min/max angles specified, not all cameras need to be created. Internally in the 1st pass shaders, we reconstruct 3d viewspace pos from depth buffer data then convert them into ranges, i.e. length(pos.xyz). 2nd Pass: Samples range data from cubemap using predefined rays. The rays are generated based on the specified vertical and horizontal min/max angles and no. of samples. Each ray is a direction vector that is used to sample/lookup the range data stored in the faces of the cubemap.
More...
| virtual | ~Ogre2GpuRays () |
| | Destructor. More...
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _channels, const std::string &_format)> _subscriber) override |
| virtual void | Copy (float *_data) override |
| | Copy to the specified memory direction the gpu rays data. More...
| virtual void | CreateRenderTexture () |
| | Create dummy render texture. Needed to satisfy inheritance. More...
| virtual const float * | Data () const override |
| | All things needed to get back z buffer for gpu rays data. More...
| | Preforms any necessary final rendering work. Once rendering is complete the camera will alert any listeners of the new frame event. This function should only be called after a call to Render has successfully been executed. More...
| virtual RenderTargetPtr | RenderTarget () const override |
| virtual | ~BaseGpuRays () |
| | Destructor. More...
| virtual ignition::math::Angle | AngleMax () const override |
| | Get maximal horizontal angle value. More...
| virtual ignition::math::Angle | AngleMin () const override |
| | Get minimal horizontal angle value. More...
| virtual unsigned int | Channels () const override |
| | Get the number of channels used to store the ray data. More...
| virtual bool | Clamp () const override |
| | Get behaviour for data values outside of camera range. More...
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber) override |
| virtual bool | IsHorizontal () const override |
| | Gets if sensor is horizontal. More...
| virtual int | RangeCount () const override |
| | Get hoizontal range count, i.e. ray count * horz resolution. More...
| virtual double | RangeCountRatio () const override |
| | Get the ray count ratio (equivalent to aspect ratio) More...
| virtual int | RayCount () const override |
| | Get horizontal quantity of rays. More...
| virtual double | RayCountRatio () const override |
| virtual RenderTargetPtr | RenderTarget () const override=0 |
| | Pointer to the render target. More...
| virtual void | SetAngleMax (double _angle) override |
| | Set maximal horizontal angle value. More...
| virtual void | SetAngleMin (double _angle) override |
| | Set minimal horizontal angle value. More...
| virtual void | SetClamp (bool _enable) override |
| | Configure behaviour for data values outside of camera range. More...
| virtual void | SetIsHorizontal (const bool _horizontal) override |
| | Set sensor horizontal or vertical. More...
| virtual void | SetRayCount (int _samples) override |
| | Set horizontal quantity of rays. More...
| virtual void | SetRayCountRatio (const double _rayCountRatio) override |
| | Sets the ray count ratio (equivalent to aspect ratio) More...
| virtual void | SetVerticalAngleMax (const double _angle) override |
| | Set maximal vertical angle value. More...
| virtual void | SetVerticalAngleMin (const double _angle) override |
| | Set minimal vertical angle value. More...
| virtual void | SetVerticalRayCount (int _samples) override |
| | Set vertical quantity of rays. More...
| virtual void | SetVFOV (const math::Angle &_vfov) |
| | Set the vertical fov. More...
| virtual ignition::math::Angle | VerticalAngleMax () const override |
| | Get maximal vertical angle value. More...
| virtual ignition::math::Angle | VerticalAngleMin () const override |
| | Get minimal vertical angle value. More...
| virtual int | VerticalRangeCount () const override |
| | Get vertical range count, i.e. ray count * vert resolution. More...
| virtual int | VerticalRayCount () const override |
| | Get vertical quantity of rays. More...
| virtual math::Angle | VFOV () const override |
| | Get the vertical field-of-view. More...
| virtual | ~GpuRays () |
| | Destructor. More...
| virtual ignition::math::Angle | AngleMax () const =0 |
| virtual ignition::math::Angle | AngleMin () const =0 |
| virtual unsigned int | Channels () const =0 |
| virtual bool | Clamp () const =0 |
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &)> _subscriber)=0 |
| | Connect to a gpu rays frame signal. More...
| virtual bool | IsHorizontal () const =0 |
| virtual int | RangeCount () const =0 |
| virtual double | RangeCountRatio () const =0 |
| virtual int | RayCount () const =0 |
| virtual double | RayCountRatio () const =0 |
| virtual ignition::math::Angle | VerticalAngleMax () const =0 |
| virtual ignition::math::Angle | VerticalAngleMin () const =0 |
| virtual int | VerticalRangeCount () const =0 |
| virtual int | VerticalRayCount () const =0 |
| virtual math::Angle | VFOV () const =0 |
| virtual | ~Camera () |
| | Deconstructor. More...
| virtual | ~Sensor () |
| | Sensor. More...
| virtual | ~Node () |
| | Destructor. More...
| virtual | ~BaseCamera () |
| virtual VisualPtr | VisualAt (const ignition::math::Vector2i &_mousePos) override |
| virtual | ~Ogre2Sensor () |
| | Destructor. More...
| virtual | ~BaseSensor () |
| virtual | ~Ogre2Node () |
| | Destructor. More...
| | Get a pointer to the underlying scene node. More...
| virtual | ~BaseNode () |
| virtual bool | InheritScale () const override=0 |
| virtual math::Vector3d | LocalScale () const override=0 |
| virtual NodePtr | Parent () const override=0 |
| virtual | ~Ogre2Object () |
| | Destructor. More...
| virtual | ~BaseObject () |
