OgreRenderPass Class Reference
Ogre implementation of the RenderPass class. More...
#include <OgreRenderPass.hh>
| virtual | ~OgreRenderPass () |
| Destructor. More... | |
| virtual void | CreateRenderPass () |
| Create the render pass using ogre compositor. More... | |
| void | Destroy () override |
| virtual void | SetCamera (Ogre::Camera *_camera) |
| Set the ogre camera that the render pass applies to. More... | |
Public Member Functions inherited from BaseRenderPass< OgreObject > | |
| virtual | ~BaseRenderPass () |
| virtual bool | IsEnabled () const override |
| virtual void | SetEnabled (bool _enabled) override |
Public Member Functions inherited from RenderPass | |
| virtual | ~RenderPass () |
| virtual bool | IsEnabled () const =0 |
Public Member Functions inherited from OgreObject | |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
| OgreRenderPass () | |
| Constructor. More... | |
Protected Member Functions inherited from BaseRenderPass< OgreObject > | |
| BaseRenderPass () | |
Protected Member Functions inherited from OgreObject | |
| OgreObject () | |
| BaseObject () | |
| virtual void | Init () |
| virtual void | Load () |
Protected Attributes | |
| Ogre::Camera * | ogreCamera = nullptr |
| Pointer to the ogre camera. More... | |
Protected Attributes inherited from BaseRenderPass< OgreObject > | |
| bool | enabled |
| Flag to indicate if render pass is enabled or not. More... | |
Protected Attributes inherited from OgreObject | |
| OgreScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ OgreRenderPass()
protected |
◆ ~OgreRenderPass()
virtual |
◆ CreateRenderPass()
virtual |
Reimplemented in OgreGaussianNoisePass.
◆ Destroy()
overridevirtual |
◆ SetCamera()
virtual |
[in] _camera Pointer to the ogre camera.
◆ ogreCamera
protected |
