BaseGeometry.hh
17 #ifndef IGNITION_RENDERING_BASE_BASEGEOMETRY_HH_
18 #define IGNITION_RENDERING_BASE_BASEGEOMETRY_HH_
20 #include <string>
21
23
26
27 namespace ignition
28 {
29  namespace rendering
30  {
31  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
32  //
33  template <class T>
34  class BaseGeometry :
35  public virtual Geometry,
36  public virtual T
37  {
38  protected: BaseGeometry();
39
40  public: virtual ~BaseGeometry();
41
42  public: virtual VisualPtr Parent() const override = 0;
43
44  public: virtual void RemoveParent() override;
45
46  // Documentation inherited
47  public: virtual void SetMaterial(const std::string &_material,
48  bool _unique = true) override;
49
50  // Documentation inherited
51  public: virtual void SetMaterial(MaterialPtr _material,
52  bool _unique = true) override = 0;
53
54  // Documentation inherited
55  public: virtual GeometryPtr Clone() const override;
56
57  // Documentation inherited
58  public: virtual void Destroy() override;
59  };
60
62  template <class T>
64  {
65  }
66
68  template <class T>
70  {
71  }
72
74  template <class T>
76  {
77  VisualPtr parent = this->Parent();
78
79  if (parent)
80  {
81  auto baseShared = this->shared_from_this();
82
83  auto thisShared =
84  std::dynamic_pointer_cast<BaseGeometry<T>>(baseShared);
85
86  parent->RemoveGeometry(thisShared);
87  }
88  }
89
91  template <class T>
92  void BaseGeometry<T>::SetMaterial(const std::string &_name, bool _unique)
93  {
94  MaterialPtr material = this->Scene()->Material(_name);
95  if (material) this->SetMaterial(material, _unique);
96  }
97
99  template <class T>
101  {
102  ignwarn << "Clone functionality for Geometry does not exist yet.\n";
103  return nullptr;
104  }
105
107  template <class T>
109  {
110  T::Destroy();
111  this->RemoveParent();
112  }
113  }
114  }
115 }
116 #endif
STL class.
STL class.
#define ignwarn
Definition: BaseGeometry.hh:69
Definition: Scene.hh:49
Definition: BaseGeometry.hh:34
virtual VisualPtr Parent() const override=0
Get the parent Visual.
Definition: BaseGeometry.hh:108
virtual MaterialPtr Material(const std::string &_name) const =0
Get material registered under the given name. If no material is registered under the given name,...
Detach this Geometry from its parent Visual. If this Geometry does not have a parent,...
Definition: BaseGeometry.hh:75
BaseGeometry()
Definition: BaseGeometry.hh:63
Clone the geometry.
Definition: BaseGeometry.hh:100
virtual void SetMaterial(const std::string &_material, bool _unique=true) override
Set the materials of this Geometry. The specified material will be retrieved from the parent Scene....
Definition: BaseGeometry.hh:92
Represents a geometric shape to be rendered.
Definition: Geometry.hh:35
