BaseGeometry< T > Class Template Referenceabstract
#include <BaseGeometry.hh>
virtual ~BaseGeometry ()
 Clone the geometry. More...
virtual void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 BaseGeometry ()
◆ BaseGeometry()
BaseGeometry
◆ ~BaseGeometry()
~BaseGeometry
◆ Clone()
GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implements Geometry.
Reimplemented in BaseMesh< OgreGeometry >, and BaseCapsule< OgreGeometry >.
void Destroy ( )
Reimplemented in BaseMesh< OgreGeometry >, OgreMesh, OgreCapsule, OgreMarker, BaseMarker< OgreGeometry >, BaseText< OgreGeometry >, BaseHeightmap< OgreGeometry >, BaseGrid< OgreGeometry >, and BaseWireBox< OgreGeometry >.
◆ Parent()
overridepure virtual
the parent Visual
◆ RemoveParent()
void RemoveParent ( )
◆ SetMaterial() [1/2]
bool  _unique = true
Reimplemented in BaseMesh< OgreGeometry >.
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseMesh< OgreGeometry >, OgreHeightmap, OgreCapsule, OgreText, OgreWireBox, OgreMarker, and OgreGrid.
