Geometry Class Referenceabstract
#include <ignition/rendering/Geometry.hh>
 Clone the geometry. More...
◆ ~Geometry()
virtual ~Geometry ( )
inlinevirtual
◆ Clone()
virtual GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implemented in BaseMesh< T >, BaseCapsule< T >, and BaseGeometry< T >.
◆ HasParent()
Implemented in OgreGeometry.
Implemented in BaseMesh< T >, OgreHeightmap, OgreCapsule, OgreText, OgreWireBox, OgreMarker, and OgreGrid.
◆ Parent()
the parent Visual
Implemented in BaseGeometry< T >, and OgreGeometry.
◆ RemoveParent()
virtual void RemoveParent ( )
Implemented in BaseGeometry< T >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [1/2]
bool  _unique = true
Implemented in BaseMesh< T >, BaseMesh< OgreGeometry >, BaseGeometry< T >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseGeometry< T >, BaseGeometry< OgreObject >, BaseMesh< T >, BaseMesh< OgreGeometry >, OgreHeightmap, OgreCapsule, OgreText, OgreWireBox, OgreMarker, and OgreGrid.
