RenderTarget.hh
4  * Licensed under the Apache License, Version 2.0 (the "License") = 0;
17 #ifndef IGNITION_RENDERING_RENDERTARGET_HH_
18 #define IGNITION_RENDERING_RENDERTARGET_HH_
20 #include <string>
21
22 #include <ignition/math/Color.hh>
23
24 #include "ignition/rendering/config.hh"
28
29 namespace ignition
30 {
31  namespace rendering
32  {
33  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
34  //
37  class IGNITION_RENDERING_VISIBLE RenderTarget :
38  public virtual Object
39  {
41  public: virtual ~RenderTarget() { }
42
45  public: virtual unsigned int Width() const = 0;
46
49  public: virtual unsigned int Height() const = 0;
50
53  public: virtual void SetWidth(const unsigned int _width) = 0;
54
57  public: virtual void SetHeight(const unsigned int _height) = 0;
58
61  public: virtual PixelFormat Format() const = 0;
62
65  public: virtual void SetFormat(PixelFormat _format) = 0;
66
73  public: virtual void Copy(Image &_image) const = 0;
74
78  public: virtual math::Color BackgroundColor() const = 0;
79
82  public: virtual void AddRenderPass(const RenderPassPtr &_pass) = 0;
83
86  public: virtual void RemoveRenderPass(const RenderPassPtr &_pass) = 0;
87
90  public: virtual unsigned int RenderPassCount() const = 0;
91
94  public: virtual RenderPassPtr RenderPassByIndex(unsigned int _index)
95  const = 0;
96  };
97
98  /* \class RenderTexture RenderTexture.hh \
99  * ignition/rendering/RenderTexture.hh
100  */
103  class IGNITION_RENDERING_VISIBLE RenderTexture :
104  public virtual RenderTarget
105  {
107  public: virtual ~RenderTexture() { }
108
110  // if this is an OpenGL render texture
111  public: virtual unsigned int GLId() const = 0;
112  };
113
114  /* \class RenderWindow RenderWindow.hh \
115  * ignition/rendering/RenderWindow.hh
116  */
119  class IGNITION_RENDERING_VISIBLE RenderWindow :
120  public virtual RenderTarget
121  {
123  public: virtual ~RenderWindow() { }
124
127  public: virtual std::string Handle() const = 0;
128
131  public: virtual void SetHandle(const std::string &_handle) = 0;
132
135  public: virtual double DevicePixelRatio() const = 0;
136
139  public: virtual void SetDevicePixelRatio(const double _ratio) = 0;
140
144  public: virtual void OnResize(unsigned int _width,
145  unsigned int _height) = 0;
146
148  public: virtual void OnMove() = 0;
149  };
150  }
151  }
152 }
153 #endif
STL class.
STL class.
virtual unsigned int RenderPassCount() const =0
Represents a off-screen render-texture to which cameras can render images.
Definition: RenderTarget.hh:103
PixelFormat
Image pixel format types.
Definition: PixelFormat.hh:32
virtual void AddRenderPass(const RenderPassPtr &_pass)=0
virtual void SetDevicePixelRatio(const double _ratio)=0
Set the device to pixel ratio.
Represents a on-screen render-window to which cameras can render images.
Definition: RenderTarget.hh:119
Definition: Image.hh:36
Definition: RenderTarget.hh:123
virtual unsigned int Width() const =0
virtual unsigned int Height() const =0
virtual void Copy(Image &_image) const =0
Write rendered image to given Image. The RenderTarget will convert the underlying image to the specif...
virtual std::string Handle() const =0
Get the window handle that the render window is attached to.
Definition: RenderTarget.hh:41
Definition: RenderTarget.hh:107
virtual math::Color BackgroundColor() const =0
virtual RenderPassPtr RenderPassByIndex(unsigned int _index) const =0
Get a render pass by index.
Definition: RenderTarget.hh:37
virtual void OnResize(unsigned int _width, unsigned int _height)=0
Alert the window of a window resize event.
virtual void SetHandle(const std::string &_handle)=0
Set the window handle to attach the render window to.
virtual double DevicePixelRatio() const =0
Get the device to pixel ratio.
Definition: Object.hh:34
virtual PixelFormat Format() const =0
virtual void SetWidth(const unsigned int _width)=0
virtual void RemoveRenderPass(const RenderPassPtr &_pass)=0
virtual void SetHeight(const unsigned int _height)=0
virtual void OnMove()=0
Alert the window of a window move event.
virtual void SetFormat(PixelFormat _format)=0
virtual unsigned int GLId() const =0
Returns the OpenGL texture Id. A valid Id is returned only.
