RenderTexture Class Referenceabstract
Represents a off-screen render-texture to which cameras can render images. More...
#include <RenderTarget.hh>
| virtual | ~RenderTexture () |
| Destructor. More... | |
| virtual unsigned int | GLId () const =0 |
| Returns the OpenGL texture Id. A valid Id is returned only. More... | |
Public Member Functions inherited from RenderTarget | |
| virtual | ~RenderTarget () |
| Add a render pass to the render target. More... | |
| virtual math::Color | BackgroundColor () const =0 |
| Get the background color of the render target. This should be the same as the scene background color. More... | |
| Write rendered image to given Image. The RenderTarget will convert the underlying image to the specified format listed in the given Image. However if the given image is not of the correct size no work will be done. Calling this function before an image has been rendered will result in undefined behavior. More... | |
| virtual PixelFormat | Format () const =0 |
| Set the render target image format. More... | |
| virtual unsigned int | Height () const =0 |
| Get render target height in pixels. More... | |
| Remove a render pass from the render target. More... | |
| Get a render pass by index. More... | |
| Get the number of render passes applied to the render target. More... | |
| virtual void | SetFormat (PixelFormat _format)=0 |
| virtual void | SetHeight (const unsigned int _height)=0 |
| Set the render target height in pixels. More... | |
| virtual void | SetWidth (const unsigned int _width)=0 |
| Set the render target width in pixels. More... | |
| virtual unsigned int | Width () const =0 |
| Get render target width in pixels. More... | |
◆ ~RenderTexture()
inlinevirtual |
◆ GLId()
pure virtual |
Implemented in BaseRenderTexture< T >.
