RenderWindow Class Referenceabstract
Represents a on-screen render-window to which cameras can render images. More...
#include <RenderTarget.hh>
virtual ~RenderWindow ()
virtual double DevicePixelRatio () const =0
virtual std::string Handle () const =0
virtual void OnMove ()=0
virtual void OnResize (unsigned int _width, unsigned int _height)=0
virtual void SetDevicePixelRatio (const double _ratio)=0
virtual void SetHandle (const std::string &_handle)=0
virtual ~RenderTarget ()
◆ ~RenderWindow()
virtual ~RenderWindow ( )
inlinevirtual
◆ DevicePixelRatio()
virtual double DevicePixelRatio ( ) const
Device to pixel ratio
Implemented in BaseRenderWindow< T >.
◆ Handle()
virtual std::string Handle ( ) const
Window handle
◆ OnMove()
virtual void OnMove ( )
Implemented in BaseRenderWindow< T >, and BaseRenderWindow< OgreRenderTarget >.
◆ OnResize()
virtual void OnResize ( unsigned int  _width,
[in]_widthNew window width in pixels
[in]_heightNew window height in pixels
◆ SetDevicePixelRatio()
virtual void SetDevicePixelRatio ( const double  _ratio)
[in]_ratioDevice to pixel ratio
◆ SetHandle()
virtual void SetHandle ( const std::string &  _handle)
[in]_handleWindow handle
