Visual.hh
17 #ifndef IGNITION_RENDERING_VISUAL_HH_
18 #define IGNITION_RENDERING_VISUAL_HH_
20 #include <string>
22 #include "ignition/rendering/config.hh"
24
25 namespace ignition
26 {
27  namespace rendering
28  {
29  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
33  class IGNITION_RENDERING_VISIBLE Visual :
34  public virtual Node
35  {
37  public: virtual ~Visual() { }
38
41  public: virtual unsigned int GeometryCount() const = 0;
42
46  public: virtual bool HasGeometry(ConstGeometryPtr _geometry) const = 0;
47
52  public: virtual GeometryPtr GeometryByIndex(
53  unsigned int _index) const = 0;
54
58  public: virtual void AddGeometry(GeometryPtr _geometry) = 0;
59
64  public: virtual GeometryPtr RemoveGeometry(GeometryPtr _geometry) = 0;
65
70  public: virtual GeometryPtr RemoveGeometryByIndex(
71  unsigned int _index) = 0;
72
74  public: virtual void RemoveGeometries() = 0;
75
82  public: virtual void SetMaterial(const std::string &_name,
83  bool _unique = true) = 0;
84
88  public: virtual void SetMaterial(MaterialPtr _material,
89  bool _unique = true) = 0;
90
94  public: virtual void SetChildMaterial(MaterialPtr _material,
95  bool _unique = true) = 0;
96
100  public: virtual void SetGeometryMaterial(MaterialPtr _material,
101  bool _unique = true) = 0;
102
107  public: virtual MaterialPtr Material() const = 0;
108
111  public: virtual void SetWireframe(bool _show) = 0;
112
115  public: virtual bool Wireframe() const = 0;
116
119  public: virtual void SetVisible(bool _visible) = 0;
120
123  public: virtual void SetVisibilityFlags(uint32_t _flags) = 0;
124
127  public: virtual uint32_t VisibilityFlags() const = 0;
128
131  public: virtual void AddVisibilityFlags(uint32_t _flags) = 0;
132
135  public: virtual void RemoveVisibilityFlags(uint32_t _flags) = 0;
136
139  public: virtual ignition::math::AxisAlignedBox BoundingBox() const = 0;
140
143  public: virtual ignition::math::AxisAlignedBox LocalBoundingBox()
144  const = 0;
145
152  public: virtual VisualPtr Clone(const std::string &_name,
153  NodePtr _newParent) const = 0;
154  };
155  }
156  }
157 }
158 #endif
virtual unsigned int GeometryCount() const =0
Definition: Node.hh:51
STL class.
STL class.
virtual VisualPtr Clone(const std::string &_name, NodePtr _newParent) const =0
virtual void SetMaterial(const std::string &_name, bool _unique=true)=0
Set the material for all attached visuals and geometries. The specified material will be retrieved fr...
2D or 3D Bounding box. It stores the position / orientation / size info of the box and its label
Definition: BoundingBox.hh:41
virtual ignition::math::AxisAlignedBox BoundingBox() const =0
virtual void SetWireframe(bool _show)=0
Enable or disable wireframe.
virtual GeometryPtr RemoveGeometry(GeometryPtr _geometry)=0
Remove the given geometry from this visual. If the given node is not a child of this visual,...
virtual GeometryPtr RemoveGeometryByIndex(unsigned int _index)=0
Remove the geometry at the given index from this visual. If the specified node is not attached this v...
virtual GeometryPtr GeometryByIndex(unsigned int _index) const =0
virtual ignition::math::AxisAlignedBox LocalBoundingBox() const =0
virtual MaterialPtr Material() const =0
virtual void AddGeometry(GeometryPtr _geometry)=0
virtual void AddVisibilityFlags(uint32_t _flags)=0
Add visibility flags.
virtual bool HasGeometry(ConstGeometryPtr _geometry) const =0
Definition: Visual.hh:33
virtual ~Visual()
Definition: Visual.hh:37
virtual void SetVisibilityFlags(uint32_t _flags)=0
Set visibility flags.
virtual bool Wireframe() const =0
virtual void SetVisible(bool _visible)=0
virtual void RemoveVisibilityFlags(uint32_t _flags)=0
Remove visibility flags.
Definition: Material.hh:47
virtual void RemoveGeometries()=0
virtual uint32_t VisibilityFlags() const =0
Get visibility flags.
virtual void SetGeometryMaterial(MaterialPtr _material, bool _unique=true)=0
virtual void SetChildMaterial(MaterialPtr _material, bool _unique=true)=0
