Material Class Referenceabstract
Represents a surface material of a Geometry. More...
#include <ignition/rendering/Material.hh>
virtual ~Material ()
virtual double AlphaThreshold () const =0
virtual math::Color Ambient () const =0
virtual void ClearEmissiveMap ()=0
virtual void ClearEnvironmentMap ()=0
virtual void ClearLightMap ()=0
virtual void ClearMetalnessMap ()=0
virtual void ClearNormalMap ()=0
virtual void ClearRoughnessMap ()=0
virtual void ClearTexture ()=0
virtual MaterialPtr Clone (const std::string &_name="") const =0
 Clone this material. More...
virtual void CopyFrom (const common::Material &_material)=0
virtual void CopyFrom (ConstMaterialPtr _material)=0
virtual bool DepthCheckEnabled () const =0
virtual bool DepthWriteEnabled () const =0
virtual math::Color Diffuse () const =0
virtual math::Color Emissive () const =0
virtual std::string EmissiveMap () const =0
virtual std::string EnvironmentMap () const =0
virtual std::string FragmentShader () const =0
virtual ShaderParamsPtr FragmentShaderParams ()=0
virtual bool HasEmissiveMap () const =0
virtual bool HasEnvironmentMap () const =0
virtual bool HasLightMap () const =0
virtual bool HasMetalnessMap () const =0
virtual bool HasNormalMap () const =0
virtual bool HasRoughnessMap () const =0
virtual bool HasTexture () const =0
virtual bool LightingEnabled () const =0
virtual std::string LightMap () const =0
virtual unsigned int LightMapTexCoordSet () const =0
virtual float Metalness () const =0
virtual std::string MetalnessMap () const =0
virtual std::string NormalMap () const =0
virtual bool ReceiveShadows () const =0
virtual bool ReflectionEnabled () const =0
virtual double Reflectivity () const =0
virtual float RenderOrder () const =0
virtual float Roughness () const =0
virtual std::string RoughnessMap () const =0
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true)=0
virtual void SetAmbient (const double _r, const double _g, const double _b, const double _a=1.0)=0
virtual void SetAmbient (const math::Color &_color)=0
virtual void SetCastShadows (const bool _castShadows)=0
virtual void SetDepthCheckEnabled (bool _enabled)=0
virtual void SetDepthMaterial (const double far, const double near)=0
virtual void SetDepthWriteEnabled (bool _enabled)=0
virtual void SetDiffuse (const double _r, const double _g, const double _b, const double _a=1.0)=0
virtual void SetDiffuse (const math::Color &_color)=0
virtual void SetEmissive (const double _r, const double _g, const double _b, const double _a=1.0)=0
virtual void SetEmissive (const math::Color &_color)=0
virtual void SetEmissiveMap (const std::string &_emissiveMap)=0
virtual void SetEnvironmentMap (const std::string &_metalnessMap)=0
virtual void SetFragmentShader (const std::string &_path)=0
virtual void SetLightingEnabled (const bool _enabled)=0
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u)=0
virtual void SetMetalness (const float _metalness)=0
virtual void SetMetalnessMap (const std::string &_metalnessMap)=0
virtual void SetNormalMap (const std::string &_normalMap)=0
virtual void SetReceiveShadows (const bool _receiveShadows)=0
virtual void SetReflectionEnabled (const bool _enabled)=0
virtual void SetReflectivity (const double _reflectivity)=0
virtual void SetRenderOrder (const float _renderOrder)=0
virtual void SetRoughness (const float _roughness)=0
virtual void SetRoughnessMap (const std::string &_roughnessMap)=0
virtual void SetShaderType (enum ShaderType _type)=0
virtual void SetShininess (const double _shininess)=0
virtual void SetSpecular (const double _r, const double _g, const double _b, const double _a=1.0)=0
virtual void SetSpecular (const math::Color &_color)=0
virtual void SetTexture (const std::string &_texture)=0
virtual void SetTransparency (const double _transparency)=0
virtual void SetVertexShader (const std::string &_path)=0
virtual enum ShaderType ShaderType () const =0
virtual double Shininess () const =0
virtual math::Color Specular () const =0
virtual std::string Texture () const =0
virtual bool TextureAlphaEnabled () const =0
virtual double Transparency () const =0
virtual bool TwoSidedEnabled () const =0
virtual enum MaterialType Type () const =0
virtual std::string VertexShader () const =0
virtual ShaderParamsPtr VertexShaderParams ()=0
◆ ~Material()
virtual ~Material ( )
inlinevirtual
◆ AlphaThreshold()
virtual double AlphaThreshold ( ) const
The alpha threshold value
Implemented in BaseMaterial< T >.
◆ Ambient()
virtual math::Color Ambient ( ) const
The ambient color
Implemented in BaseMaterial< T >, and OgreMaterial.
◆ CastShadows()
◆ ClearEmissiveMap()
virtual void ClearEmissiveMap ( )
Implemented in BaseMaterial< T >, and BaseMaterial< OgreObject >.
◆ ClearEnvironmentMap()
virtual void ClearEnvironmentMap ( )
◆ ClearLightMap()
virtual void ClearLightMap ( )
◆ ClearMetalnessMap()
virtual void ClearMetalnessMap ( )
◆ ClearNormalMap()
Implemented in BaseMaterial< T >, BaseMaterial< OgreObject >, and OgreMaterial.
◆ ClearRoughnessMap()
virtual void ClearRoughnessMap ( )
◆ ClearTexture()
virtual void ClearTexture ( )
◆ Clone()
virtual MaterialPtr Clone ( const std::string &  _name = "") const
New cloned material
◆ CopyFrom() [1/2]
virtual void CopyFrom ( const common::Material &  _material)
[in]_materialSource Material to be copied from
◆ CopyFrom() [2/2]
virtual void CopyFrom ( ConstMaterialPtr  _material)
◆ DepthCheckEnabled()
◆ DepthWriteEnabled()
◆ Diffuse()
The diffuse color
◆ Emissive()
The emissive color
◆ EmissiveMap()
virtual std::string EmissiveMap ( ) const
◆ EnvironmentMap()
virtual std::string EnvironmentMap ( ) const
◆ FragmentShader()
Path to fragment shader
◆ FragmentShaderParams()
editable parameters
◆ HasEmissiveMap()
virtual bool HasEmissiveMap ( ) const
◆ HasEnvironmentMap()
virtual bool HasEnvironmentMap ( ) const
◆ HasLightMap()
virtual bool HasLightMap ( ) const
True if this material has a light map
◆ HasMetalnessMap()
virtual bool HasMetalnessMap ( ) const
◆ HasNormalMap()
◆ HasRoughnessMap()
virtual bool HasRoughnessMap ( ) const
◆ HasTexture()
◆ LightingEnabled()
virtual bool LightingEnabled ( ) const
◆ LightMap()
virtual std::string LightMap ( ) const
◆ LightMapTexCoordSet()
virtual unsigned int LightMapTexCoordSet ( ) const
texture coordinate set of the light map
◆ Metalness()
virtual float Metalness ( ) const
Material metalness
◆ MetalnessMap()
virtual std::string MetalnessMap ( ) const
◆ NormalMap()
◆ ReceiveShadows()
◆ ReflectionEnabled()
virtual bool ReflectionEnabled ( ) const
◆ Reflectivity()
virtual double Reflectivity ( ) const
The reflectivity value
◆ RenderOrder()
Material render order
◆ Roughness()
virtual float Roughness ( ) const
Material roughness
◆ RoughnessMap()
virtual std::string RoughnessMap ( ) const
◆ SetAlphaFromTexture()
double  _alpha = 0.5,
bool  _twoSided = true
Implemented in OgreMaterial, BaseMaterial< T >, and BaseMaterial< OgreObject >.
◆ SetAmbient() [1/2]
virtual void SetAmbient ( const double  _r,
const double  _g,
const double  _b,
const double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetAmbient() [2/2]
virtual void SetAmbient ( const math::Color &  _color)
[in]_colorNew ambient color
◆ SetCastShadows()
virtual void SetCastShadows ( const bool  _castShadows)
◆ SetDepthCheckEnabled()
◆ SetDepthMaterial()
virtual void SetDepthMaterial ( const double  far,
const double  near
◆ SetDepthWriteEnabled()
◆ SetDiffuse() [1/2]
virtual void SetDiffuse ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetDiffuse() [2/2]
[in]_colorNew diffuse color
◆ SetEmissive() [1/2]
virtual void SetEmissive ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetEmissive() [2/2]
[in]_colorNew emissive color
◆ SetEmissiveMap()
virtual void SetEmissiveMap ( const std::string &  _emissiveMap)
[in]_emissiveMapURI of the new emissive map file
◆ SetEnvironmentMap()
virtual void SetEnvironmentMap ( const std::string &  _metalnessMap)
[in]_metalnessMapURI of the new environment map file
◆ SetFragmentShader()
◆ SetLightingEnabled()
virtual void SetLightingEnabled ( const bool  _enabled)
◆ SetLightMap()
virtual void SetLightMap ( const std::string &  _lightMap,
unsigned int  _uvSet = 0u
[in]_lightMapURI of the new light map file
[in]_uvSetTexture coordinate set to use
◆ SetMetalness()
virtual void SetMetalness ( const float  _metalness)
◆ SetMetalnessMap()
virtual void SetMetalnessMap ( const std::string &  _metalnessMap)
[in]_metalnessMapURI of the new metalness map file
◆ SetNormalMap()
virtual void SetNormalMap ( const std::string &  _normalMap)
[in]_normalMapURI of the new normal map file
◆ SetReceiveShadows()
◆ SetReflectionEnabled()
virtual void SetReflectionEnabled ( const bool  _enabled)
◆ SetReflectivity()
virtual void SetReflectivity ( const double  _reflectivity)
◆ SetRenderOrder()
◆ SetRoughness()
virtual void SetRoughness ( const float  _roughness)
◆ SetRoughnessMap()
virtual void SetRoughnessMap ( const std::string &  _roughnessMap)
[in]_roughnessMapURI of the new roughness map file
◆ SetShaderType()
[in]_typeNew ShaderType value
◆ SetShininess()
virtual void SetShininess ( const double  _shininess)
◆ SetSpecular() [1/2]
virtual void SetSpecular ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SetSpecular() [2/2]
[in]_colorNew specular color
◆ SetTexture()
virtual void SetTexture ( const std::string &  _texture)
[in]_textureURI of the new texture file
◆ SetTransparency()
◆ SetVertexShader()
◆ ShaderType()
The ShaderType value
◆ Shininess()
virtual double Shininess ( ) const
The shininess value
◆ Specular()
The specular color
◆ Texture()
◆ TextureAlphaEnabled()
virtual bool TextureAlphaEnabled ( ) const
The enable alpha value
◆ Transparency()
virtual double Transparency ( ) const
The transparency value
◆ TwoSidedEnabled()
virtual bool TwoSidedEnabled ( ) const
The enable two sided rendering value
◆ Type()
virtual enum MaterialType Type ( ) const
◆ VertexShader()
Path to vertex shader
◆ VertexShaderParams()
editable parameters
