BoundingBox Class Reference
2D or 3D Bounding box. It stores the position / orientation / size info of the box and its label More...
#include <BoundingBox.hh>
 BoundingBox ()
 BoundingBox (BoundingBox &&_box) noexcept
 Move constructor. More...
 BoundingBox (const BoundingBox &_box)
 Copy constructor. More...
virtual ~BoundingBox ()
const math::Vector3d & Center () const
 Get the center of the bounding box. More...
uint32_t Label () const
 Get the label of the bounding box. More...
BoundingBox & operator= (BoundingBox &&_box)
 Move assignment operator. More...
BoundingBox & operator= (const BoundingBox &_box)
 Copy Assignment operator. More...
const math::Quaterniond & Orientation () const
 Get the orientation of the bounding box. More...
void SetCenter (const math::Vector3d &_center)
 Set the center of the bounding box. More...
void SetLabel (uint32_t _label)
 Set the label of the bounding box. More...
void SetOrientation (const math::Quaterniond &_orientation)
 Set the orientation of the bounding box. More...
void SetSize (const math::Vector3d &_size)
 Set the size of the bounding box. More...
const math::Vector3d & Size () const
 Get the size of the bounding box. More...
const std::vector< math::Vector3d > & Vertices3D () const
 Get the vertices of the 3D bounding box representation. More...
◆ BoundingBox() [1/3]
◆ BoundingBox() [2/3]
BoundingBox ( const BoundingBox &  _box)
Copy constructor.
[in]_boxBoundingBox to copy.
◆ BoundingBox() [3/3]
BoundingBox ( BoundingBox &&  _box)
noexcept
Move constructor.
[in]_boxBoundingBox to move.
◆ ~BoundingBox()
virtual ~BoundingBox ( )
◆ Center()
const math::Vector3d& Center ( ) const
The center of the bounding box, in (x,y,z) representation. If this is a 2D bounding box, the z component should be ignored.
◆ Label()
uint32_t Label ( ) const
The label of the bounding box.
◆ operator=() [1/2]
BoundingBox& operator= ( BoundingBox &&  _box)
[in]_boxHeightmap box to move.
Reference to this.
◆ operator=() [2/2]
BoundingBox& operator= ( const BoundingBox &  _box)
[in]_boxThe heightmap box to set values from.
*this
◆ Orientation()
const math::Quaterniond& Orientation ( ) const
The orientation of the bounding box, in camera coordinates.
◆ SetCenter()
void SetCenter ( const math::Vector3d &  _center)
[in]_centerThe center of the bounding box, in (x,y,z) representation. If this is a 2D bounding box, the z component should be ignored.
◆ SetLabel()
void SetLabel ( uint32_t  _label)
[in]_labelThe label of the bounding box.
◆ SetOrientation()
void SetOrientation ( const math::Quaterniond &  _orientation)
[in]_orientationThe orientation of the bounding box, in camera coordinates.
◆ SetSize()
void SetSize ( const math::Vector3d &  _size)
[in]_sizeThe size of the box (width, height, depth). If this is a 2D bounding box, the depth should be ignored.
◆ Size()
const math::Vector3d& Size ( ) const
◆ Vertices3D()
const std::vector<math::Vector3d>& Vertices3D ( ) const
The vertices, in the following order:
1 -----— 0 /| /| 2 -----— 3 . | | | | . 5 -----— 4 |/ |/ 6 -----— 7
