Heightmap Class Referenceabstract
A terrain defined by a heightfield. More...
#include <ignition/rendering/Heightmap>
virtual const HeightmapDescriptor & Descriptor ()=0
 Get the immutable heightmap descriptor. More...
 Clone the geometry. More...
◆ Descriptor()
virtual const HeightmapDescriptor& Descriptor ( )
Descriptor with heightmap information.
Implemented in BaseHeightmap< T >, and BaseHeightmap< OgreGeometry >.
