DirectionalLight Class Referenceabstract
Represents a infinite directional light. More...
virtual ~DirectionalLight ()
virtual ~Light ()
◆ ~DirectionalLight()
virtual ~DirectionalLight ( )
inlinevirtual
◆ Direction()
The direction of the light
Implemented in OgreDirectionalLight.
◆ SetDirection() [1/2]
[in]_dirNew direction vector
Implemented in BaseDirectionalLight< T >, BaseDirectionalLight< OgreLight >, and OgreDirectionalLight.
◆ SetDirection() [2/2]
double  _y,
double  _z
Implemented in BaseDirectionalLight< T >, and BaseDirectionalLight< OgreLight >.
