#include <OgreLight.hh>
virtual ~OgreDirectionalLight ()
virtual math::Vector3d Direction () const
virtual void SetDirection (const math::Vector3d &_dir)
- Public Member Functions inherited from BaseDirectionalLight< OgreLight >
virtual ~BaseDirectionalLight ()
- Public Member Functions inherited from DirectionalLight
virtual ~DirectionalLight ()
virtual ~Light ()
virtual ~OgreLight ()
virtual ~BaseLight ()
virtual ~OgreNode ()
- Protected Member Functions inherited from BaseDirectionalLight< OgreLight >
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreDirectionalLight()
OgreDirectionalLight ( )
◆ ~OgreDirectionalLight()
virtual ~OgreDirectionalLight ( )
◆ Direction()
The direction of the light
Implements DirectionalLight.
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseDirectionalLight< OgreLight >.
