| | GaussianNoisePass () |
| | Constructor. More...
| virtual | ~GaussianNoisePass () |
| | Destructor. More...
| virtual double | Bias () const =0 |
| | Accessor for bias. More...
| virtual double | Mean () const =0 |
| | Accessor for mean. More...
| virtual void | SetBiasMean (double _biasMean)=0 |
| | Set the mean of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
| virtual void | SetBiasStdDev (double _biasStdDev)=0 |
| | Set the standard deviation of the bias value. Bias is computed based on the bias mean and bias standard deviation. More...
| virtual void | SetMean (double _mean)=0 |
| | Set mean. More...
| virtual void | SetStdDev (double _stdDev)=0 |
| | Set stddev. More...
| virtual double | StdDev () const =0 |
| | Accessor for stddev. More...
| virtual | ~RenderPass () |
| | Destructor. More...
| virtual bool | IsEnabled () const =0 |
| | Get whether or not the render pass is enabled. More...
| virtual void | SetEnabled (bool _enabled)=0 |
| | Set to enable or disable the render pass. More...
| | Destructor. More...
A render pass that applies Gaussian noise to the render target.
