RenderPass Class Referenceabstract
#include <ignition/rendering/RenderPass.hh>
| virtual | ~RenderPass () |
| Destructor. More... | |
| virtual bool | IsEnabled () const =0 |
| virtual void | SetEnabled (bool _enabled)=0 |
◆ ~RenderPass()
inlinevirtual |
◆ IsEnabled()
pure virtual |
- Returns
- True if the render pass is enabled, false otherwise.
Implemented in BaseRenderPass< T >.
◆ SetEnabled()
pure virtual |
[in] _enabled True to enable the render pass, false to disable.
Implemented in BaseRenderPass< T >, and BaseRenderPass< OgreObject >.
