PointLight Class Reference
| virtual | ~PointLight () |
| Destructor. More... | |
Public Member Functions inherited from Light | |
| virtual | ~Light () |
| virtual double | AttenuationConstant () const =0 |
| Get the attenuation constant value. More... | |
| virtual double | AttenuationLinear () const =0 |
| Get the attenuation linear value. More... | |
| virtual double | AttenuationQuadratic () const =0 |
| Get the attenuation quadratic value. More... | |
| virtual double | AttenuationRange () const =0 |
| Get the attenuation range. More... | |
| virtual bool | CastShadows () const =0 |
| Determine if this light cast shadows. More... | |
| virtual math::Color | DiffuseColor () const =0 |
| Get the diffuse color. More... | |
| virtual double | Intensity () const =0 |
| Get the light intensity. More... | |
| virtual void | SetAttenuationConstant (double _value)=0 |
| Set the attenuation constant value. More... | |
| virtual void | SetAttenuationLinear (double _value)=0 |
| Set the attenuation linear value. More... | |
| virtual void | SetAttenuationQuadratic (double _value)=0 |
| Set the attenuation quadratic value. More... | |
| virtual void | SetAttenuationRange (double _range)=0 |
| Set the attenuation range. More... | |
| virtual void | SetCastShadows (bool _castShadows)=0 |
| Specify if this light should cast shadows. More... | |
| virtual void | SetDiffuseColor (const math::Color &_color)=0 |
| Set the diffuse color. More... | |
| virtual void | SetDiffuseColor (double _r, double _g, double _b, double _a=1.0)=0 |
| virtual void | SetIntensity (double _intensity)=0 |
| Set the light intensity. More... | |
| virtual void | SetSpecularColor (const math::Color &_color)=0 |
| Set the specular color. More... | |
| virtual void | SetSpecularColor (double _r, double _g, double _b, double _a=1.0)=0 |
| virtual math::Color | SpecularColor () const =0 |
| Get the specular color. More... | |
| virtual | ~Node () |
◆ ~PointLight()
inlinevirtual |
