Sensor Class Referenceabstract
#include <ignition/rendering/Sensor.hh>
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
| Destructor. More... | |
◆ ~Sensor()
◆ SetVisibilityMask()
pure virtual |
[in] _mask Visibility mask
Implemented in OgreCamera, BaseSensor< T >, and BaseSensor< OgreNode >.
◆ VisibilityMask()
pure virtual |
