#include <OgreCamera.hh>
virtual ~OgreCamera ()
virtual math::Color BackgroundColor () const
Ogre::Camera * Camera () const
 Get underlying Ogre camera. More...
double FarClip () const
 Get the far clip distance. More...
double NearClip () const
 Get the near clip distance. More...
virtual void SetBackgroundColor (const math::Color &_color)
void SetVFOV (double cameraVFOV) const
 Set visibility mask. More...
virtual ~BaseCamera ()
virtual ~Camera ()
 Sensor. More...
 Get visibility mask. More...
virtual ~OgreSensor ()
virtual ~BaseSensor ()
virtual ~OgreNode ()
 OgreCamera ()
virtual void SetSelectionBuffer ()
 BaseCamera ()
virtual RenderTargetPtr RenderTarget () const=0
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
math::Color backgroundColor
OgreRenderTargetPtr renderTexture
OgreSelectionBuffer * selectionBuffer = nullptr
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreCamera()
OgreCamera ( )
◆ ~OgreCamera()
virtual ~OgreCamera ( )
◆ AntiAliasing()
Implements Camera.
◆ AspectRatio()
The camera's aspect ratio
Implements Camera.
◆ BackgroundColor()
◆ Camera()
Ogre::Camera* Camera ( ) const
◆ CreateRenderTexture()
◆ CreateRenderWindow()
Reimplemented from OgreNode.
◆ FarClip()
double FarClip ( ) const
Far clip distance
◆ HFOV()
virtual math::Angle HFOV ( ) const
Implements Camera.
◆ NearClip()
double NearClip ( ) const
Near clip distance
◆ ProjectionMatrix()
Camera projection matrix
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
Implements Camera.
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
◆ SetBackgroundColor()
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetProjectionMatrix()
◆ SetProjectionType()
virtual void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ SetVFOV()
void SetVFOV ( double  cameraVFOV) const
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implements Sensor.
◆ ViewMatrix()
Camera view matrix
Implements Camera.
◆ VisualAt()
virtual VisualPtr VisualAt ( const ignition::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
OgreSelectionBuffer* selectionBuffer = nullptr
