Storage.hh
17 #ifndef IGNITION_RENDERING_STORAGE_HH_
18 #define IGNITION_RENDERING_STORAGE_HH_
20 #include <memory>
21 #include <string>
22 #include "ignition/rendering/config.hh"
31 #include "ignition/rendering/Export.hh"
32
33 // An X11 header file defines a macro that conflicts with our function name,
34 // so undefine it here
35 #ifdef DestroyAll
36 #undef DestroyAll
37 #endif
38
39 namespace ignition
40 {
41  namespace rendering
42  {
43  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
44  //
48  template <class T>
49  class IGNITION_RENDERING_VISIBLE Map
50  {
53  typedef std::shared_ptr<T> TPtr;
54
58
60  public: virtual ~Map() { }
61
64  public: virtual unsigned int Size() const = 0;
65
69  public: virtual bool ContainsKey(const std::string &_key) const = 0;
70
74  public: virtual bool ContainsValue(ConstTPtr _value) const = 0;
75
79  public: virtual TPtr Get(const std::string &_key) const = 0;
80
84  public: virtual TPtr GetByIndex(unsigned int _index) const = 0;
85
91  public: virtual bool Put(const std::string &_key, TPtr _value) = 0;
92
96  public: virtual void Remove(const std::string &_key) = 0;
97
101  public: virtual void Remove(TPtr _value) = 0;
102
104  public: virtual void RemoveAll() = 0;
105  };
106
113  template <class T>
114  class IGNITION_RENDERING_VISIBLE Store
115  {
118  typedef std::shared_ptr<T> TPtr;
119
123
125  public: virtual ~Store() { }
126
129  public: virtual unsigned int Size() const = 0;
130
134  public: virtual bool Contains(ConstTPtr _object) const = 0;
135
139  public: virtual bool ContainsId(unsigned int _id) const = 0;
140
144  public: virtual bool ContainsName(const std::string &_name) const = 0;
145
149  public: virtual TPtr GetById(unsigned int _id) const = 0;
150
154  public: virtual TPtr GetByName(const std::string &_name) const = 0;
155
159  public: virtual TPtr GetByIndex(unsigned int _index) const = 0;
160
166  public: virtual bool Add(TPtr _object) = 0;
167
172  public: virtual TPtr Remove(TPtr _object) = 0;
173
178  public: virtual TPtr RemoveById(unsigned int _id) = 0;
179
184  public: virtual TPtr RemoveByName(const std::string &_name) = 0;
185
190  public: virtual TPtr RemoveByIndex(unsigned int _index) = 0;
191
193  public: virtual void RemoveAll() = 0;
194
198  public: virtual void Destroy(TPtr _object) = 0;
199
203  public: virtual void DestroyById(unsigned int _id) = 0;
204
209  public: virtual void DestroyByName(const std::string &_name) = 0;
210
215  public: virtual void DestroyByIndex(unsigned int _index) = 0;
216
218  public: virtual void DestroyAll() = 0;
219  };
220
226  template <class T>
227  class IGNITION_RENDERING_VISIBLE CompositeStore :
228  public Store<T>
229  {
232  typedef std::shared_ptr<T> TPtr;
233
236  typedef Store<T> TStore;
237
241
245
247  public: virtual ~CompositeStore() { }
248
251  public: virtual unsigned int GetStoreCount() const = 0;
252
256  public: virtual bool ContainsStore(ConstTStorePtr _store) const = 0;
257
262  public: virtual bool AddStore(TStorePtr _store) = 0;
263
268  public: virtual TStorePtr GetStore(unsigned int _index) const = 0;
269
274  public: virtual TStorePtr RemoveStore(TStorePtr _store) = 0;
275
280  public: virtual TStorePtr RemoveStore(unsigned int _index) = 0;
281  };
282
290  template <class T, class U>
291  class IGNITION_RENDERING_VISIBLE StoreWrapper :
292  public Store<T>
293  {
294  public: virtual ~StoreWrapper() { }
295  };
296
297 // armhf failed to build with this code. It can not be removed for the rest
298 // of arches to keep ABI but should be removed in major versions unreleased
299 // see https://github.com/ignitionrobotics/ign-rendering/pull/457
300 #ifndef __ARM_PCS_VFP
301  template class Store<Scene>;
302  template class Store<Node>;
303  template class Store<Light>;
304  template class Store<Sensor>;
305  template class Store<Visual>;
306  template class Store<Geometry>;
307  template class Store<SubMesh>;
308  template class Map<Material>;
309  template class CompositeStore<Node>;
310 #endif
311
315
319
323
327
331
335
339
343
347
351
355
359
363
367
371
375
379
383  }
384  }
385 }
386 #endif
Represents a collection of Store objects, collectively working as a single composite store...
Definition: Storage.hh:227
std::shared_ptr< NodeCompositeStore > NodeCompositeStorePtr
Definition: Storage.hh:382
Store< Geometry > GeometryStore
Definition: Storage.hh:334
std::shared_ptr< VisualStore > VisualStorePtr
Definition: Storage.hh:366
Definition: Storage.hh:247
Store< Scene > SceneStore
Definition: Storage.hh:314
std::shared_ptr< NodeStore > NodeStorePtr
Definition: Storage.hh:354
virtual ~Store()
Definition: Storage.hh:125
std::shared_ptr< SubMeshStore > SubMeshStorePtr
Definition: Storage.hh:374
std::shared_ptr< GeometryStore > GeometryStorePtr
Definition: Storage.hh:370
Store< Visual > VisualStore
Definition: Storage.hh:330
Store< Light > LightStore
Definition: Storage.hh:322
virtual ~Map()
Definition: Storage.hh:60
Map< Material > MaterialMap
Definition: Storage.hh:342
std::shared_ptr< SceneStore > SceneStorePtr
Definition: Storage.hh:350
std::shared_ptr< MaterialMap > MaterialMapPtr
Definition: Storage.hh:378
STL class.
Store< SubMesh > SubMeshStore
Definition: Storage.hh:338
Store< Node > NodeStore
Definition: Storage.hh:318
Definition: Storage.hh:294
std::shared_ptr< SensorStore > SensorStorePtr
Definition: Storage.hh:362
Storage map from std::string to template class T.
Definition: Storage.hh:49
Multi-access storage structure of template class T. Template class T is expected to have functions Ge...
Definition: Storage.hh:114
CompositeStore< Node > NodeCompositeStore
Definition: Storage.hh:346
Store< Sensor > SensorStore
Definition: Storage.hh:326
Simple wrapper class that allows a Store of type Derived to be treated as a Store of type Base...
Definition: Storage.hh:291
std::shared_ptr< LightStore > LightStorePtr
Definition: Storage.hh:358
