Store< T > Class Template Referenceabstract
#include <ignition/rendering/Storage.hh>
virtual ~Store ()
virtual void DestroyAll ()=0
virtual void RemoveAll ()=0
template<class T>
class ignition::rendering::Store< T >
Template Parameters
TThe storage element type
◆ ~Store()
virtual ~Store ( )
inlinevirtual
◆ Add()
virtual bool Add ( TPtr  _object)
True if successful
Implemented in BaseStoreWrapper< T, U >, BaseCompositeStore< T >, BaseCompositeStore< Node >, BaseStore< T, U >, BaseStore< Light, T >, BaseStore< SubMesh, T >, BaseStore< Node, T >, BaseStore< Geometry, T >, BaseStore< Scene, T >, BaseStore< Visual, T >, and BaseStore< Sensor, T >.
◆ Contains()
virtual bool Contains ( ConstTPtr  _object) const
◆ ContainsId()
virtual bool ContainsId ( unsigned int  _id) const
◆ ContainsName()
virtual bool ContainsName ( const std::string &  _name) const
virtual void Destroy ( TPtr  _object)
◆ DestroyAll()
◆ DestroyById()
virtual void DestroyById ( unsigned int  _id)
◆ DestroyByIndex()
virtual void DestroyByIndex ( unsigned int  _index)
◆ DestroyByName()
virtual void DestroyByName ( const std::string &  _name)
◆ GetById()
virtual TPtr GetById ( unsigned int  _id) const
◆ GetByIndex()
◆ GetByName()
virtual TPtr GetByName ( const std::string &  _name) const
◆ Remove()
virtual TPtr Remove ( TPtr  _object)
The removed element
◆ RemoveAll()
◆ RemoveById()
virtual TPtr RemoveById ( unsigned int  _id)
The removed element
◆ RemoveByIndex()
virtual TPtr RemoveByIndex ( unsigned int  _index)
The removed element
◆ RemoveByName()
virtual TPtr RemoveByName ( const std::string &  _name)
The removed element
◆ Size()
