CompositeStore< T > Class Template Referenceabstract
#include <ignition/rendering/Storage.hh>
virtual ~CompositeStore ()
virtual bool AddStore (TStorePtr _store)=0
 Add the given store. If the given store already exists, then no work will be done. More...
virtual bool ContainsStore (ConstTStorePtr _store) const =0
 Determine if given store exists. More...
virtual TStorePtr GetStore (unsigned int _index) const =0
 Get store at the given index. If no such store exists NULL will be returned. More...
virtual unsigned int GetStoreCount () const =0
 Get number of Stores. More...
virtual TStorePtr RemoveStore (TStorePtr _store)=0
 Remove given store. If no such store exists no work will be done and NULL will be returned. More...
virtual TStorePtr RemoveStore (unsigned int _index)=0
 Remove store at the given index. If no such store exists no work will be done and NULL will be returned. More...
virtual ~Store ()
virtual void DestroyAll ()=0
virtual void RemoveAll ()=0
template<class T>
class ignition::rendering::CompositeStore< T >
ignition/rendering/CompositeStore.hh
Template Parameters
TThe storage element type
◆ ~CompositeStore()
virtual ~CompositeStore ( )
inlinevirtual
◆ AddStore()
virtual bool AddStore ( TStorePtr  _store)
[in]_storeStore to be added
True if successful
Implemented in BaseCompositeStore< T >, and BaseCompositeStore< Node >.
◆ ContainsStore()
virtual bool ContainsStore ( ConstTStorePtr  _store) const
[in]_storeStore in question
True if given store exists
◆ GetStore()
virtual TStorePtr GetStore ( unsigned int  _index) const
[in]_indexIndex of the desired store
The specified store
◆ GetStoreCount()
virtual unsigned int GetStoreCount ( ) const
The number of Stores
◆ RemoveStore() [1/2]
virtual TStorePtr RemoveStore ( TStorePtr  _store)
[in]_storeStore to be removed
The removed store
◆ RemoveStore() [2/2]
virtual TStorePtr RemoveStore ( unsigned int  _index)
[in]_indexIndex of the store to be removed
The removed store
