BaseAxisVisual< T > Class Template Reference
#include <BaseAxisVisual.hh>
virtual ~BaseAxisVisual ()
 set true to show the axis heads, false otherwise More...
 set true to show the specified axis head, false otherwise More...
virtual ~AxisVisual ()
virtual ~CompositeVisual ()
 BaseAxisVisual ()
◆ BaseAxisVisual()
BaseAxisVisual ( )
◆ ~BaseAxisVisual()
~BaseAxisVisual ( )
void Destroy ( )
void Init ( )
◆ LocalScale()
math::Vector3d LocalScale ( ) const
The local scale
Implements Node.
◆ SetLocalScale()
[in]_scaleNew local scale
Implements Node.
◆ SetVisible()
Implements Visual.
◆ ShowAxisHead() [1/2]
void ShowAxisHead ( bool  _b)
[in]_btrue to show the axis heads, false otherwise
Implements AxisVisual.
◆ ShowAxisHead() [2/2]
void ShowAxisHead ( unsigned int  _axis,
bool  _b
[in]_axisAxis index. 0: x, 1: y, 2: z
[in]_btrue to show the specified axis head, false otherwise
