A base implementation of the GizmoVisual class. More...
#include <BaseGizmoVisual.hh>
virtual ~BaseGizmoVisual ()
 Reset the gizmo visual state. More...
virtual ~GizmoVisual ()
virtual ~CompositeVisual ()
Protected Types
enum  AxisMaterial {
  AM_X, AM_Y, AM_Z, AM_ACTIVE,
  AM_O, AM_HANDLE
 BaseGizmoVisual ()
void CreateMaterials ()
 Create materials used by the gizmo visual. More...
void CreateRotationVisual ()
 Create gizmo visual for rotation. More...
void CreateScaleVisual ()
 Create gizmo visual for scale. More...
 Create gizmo visual for translation. More...
VisualPtr activeVis
 Currently active visual. More...
math::Vector3d axis = math::Vector3d::Zero
 Active axis. More...
 A map of gizmo axis and their handle visuals. More...
 A map of axis enums to materials. More...
TransformMode mode = TransformMode::TM_NONE
 Current gizmo mode. More...
bool modeDirty = false
 Flag to indicate the mode has changed. More...
 A map of gizmo axis and their visuals. More...
template<class T>
class ignition::rendering::BaseGizmoVisual< T >
◆ AxisMaterial
enum AxisMaterial
Enumerator
AM_X
X axis.
AM_Y
Y axis.
AM_Z
Z axis.
AM_ACTIVE
Active axis.
AM_O
Origin.
AM_HANDLE
handle
◆ BaseGizmoVisual()
BaseGizmoVisual ( )
◆ ~BaseGizmoVisual()
~BaseGizmoVisual ( )
◆ ActiveAxis()
math::Vector3d ActiveAxis ( ) const
Active axis
SetActiveAxis
Implements GizmoVisual.
◆ AxisById()
TransformAxis AxisById ( unsigned int  _id) const
◆ ChildByAxis()
VisualPtr ChildByAxis ( unsigned int  _axis) const
TransformAxis, TransformMode
◆ CreateMaterials()
void CreateMaterials ( )
Referenced by BaseGizmoVisual< Ogre2Visual >::Init().
◆ CreateRotationVisual()
void CreateRotationVisual ( )
◆ CreateScaleVisual()
void CreateScaleVisual ( )
◆ CreateTranslationVisual()
void CreateTranslationVisual ( )
void Init ( )
◆ Mode()
TransformMode Mode ( ) const
Transform mode
SetTransformMode
void PreRender ( )
◆ Reset()
void Reset ( )
Referenced by BaseGizmoVisual< Ogre2Visual >::PreRender().
◆ SetActiveAxis()
void SetActiveAxis ( const math::Vector3d &  _axis)
◆ SetTransformMode()
void SetTransformMode ( TransformMode  _mode)
GizmoMode
◆ activeVis
VisualPtr activeVis
◆ axis
◆ handles
◆ materials
◆ mode
◆ modeDirty
◆ visuals
