#include <BaseMaterial.hh>
virtual ~BaseMaterial ()
double AlphaThreshold () const override
virtual void ClearLightMap () override
 Clone this material. More...
virtual bool HasLightMap () const override
virtual std::string LightMap () const override
virtual unsigned int LightMapTexCoordSet () const override
virtual float RenderOrder () const override
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true) override
virtual void SetEmissiveMap (const std::string &_emissiveMap) override
virtual void SetEnvironmentMap (const std::string &_metalnessMap) override
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u) override
virtual void SetMetalness (const float _metalness) override
virtual void SetMetalnessMap (const std::string &_metalnessMap) override
virtual void SetNormalMap (const std::string &_normalMap) override
virtual void SetRenderOrder (const float _renderOrder) override
virtual void SetRoughnessMap (const std::string &_roughnessMap) override
virtual void SetTexture (const std::string &_texture) override
bool TextureAlphaEnabled () const override
bool TwoSidedEnabled () const override
virtual ~Material ()
 BaseMaterial ()
double alphaThreshold = 0.5
 Threshold for alpha channel rejection. More...
math::Color ambient
 Ambient color. More...
bool castShadows = true
bool depthCheckEnabled = true
bool depthWriteEnabled = true
math::Color diffuse
 Diffuse color. More...
math::Color emissive
 Emissive color. More...
bool lightingEnabled = false
bool receiveShadows = true
bool reflectionEnabled = false
double reflectivity = 0.0
 Reflectivity. More...
double renderOrder = 0.0
 Material render order. More...
double shininess = 0.0
 Shininess factor. More...
math::Color specular
 Specular color. More...
bool textureAlphaEnabled = false
 Enable alpha channel based texture transparency. More...
double transparency = 0.0
bool twoSidedEnabled = false
 Enable two sided rendering. More...
◆ BaseMaterial()
BaseMaterial ( )
◆ ~BaseMaterial()
~BaseMaterial ( )
◆ AlphaThreshold()
double AlphaThreshold ( ) const
The alpha threshold value
Implements Material.
◆ Ambient()
math::Color Ambient ( ) const
The ambient color
Reimplemented in OgreMaterial.
◆ CastShadows()
bool CastShadows ( ) const
◆ ClearEmissiveMap()
void ClearEmissiveMap ( )
Reimplemented in Ogre2Material.
Referenced by BaseMaterial< OgreObject >::Reset().
◆ ClearEnvironmentMap()
void ClearEnvironmentMap ( )
◆ ClearLightMap()
void ClearLightMap ( )
◆ ClearMetalnessMap()
void ClearMetalnessMap ( )
◆ ClearNormalMap()
void ClearNormalMap ( )
Reimplemented in OgreMaterial, and Ogre2Material.
Referenced by BaseMaterial< OgreObject >::CopyFrom(), and BaseMaterial< OgreObject >::Reset().
◆ ClearRoughnessMap()
void ClearRoughnessMap ( )
◆ ClearTexture()
void ClearTexture ( )
◆ Clone()
MaterialPtr Clone ( const std::string &  _name = "") const
New cloned material
◆ CopyFrom() [1/2]
void CopyFrom ( ConstMaterialPtr  _material)
[in]_materialSource Material to be copied from
Referenced by BaseMaterial< OgreObject >::ShaderType().
◆ CopyFrom() [2/2]
void CopyFrom ( const common::Material &  _material)
◆ DepthCheckEnabled()
bool DepthCheckEnabled ( ) const
Reimplemented in Ogre2Material, and OgreMaterial.
◆ DepthWriteEnabled()
bool DepthWriteEnabled ( ) const
◆ Diffuse()
math::Color Diffuse ( ) const
The diffuse color
◆ Emissive()
math::Color Emissive ( ) const
The emissive color
◆ EmissiveMap()
std::string EmissiveMap ( ) const
◆ EnvironmentMap()
std::string EnvironmentMap ( ) const
◆ FragmentShader()
std::string FragmentShader ( ) const
Path to fragment shader
◆ FragmentShaderParams()
ShaderParamsPtr FragmentShaderParams ( )
editable parameters
◆ HasEmissiveMap()
bool HasEmissiveMap ( ) const
◆ HasEnvironmentMap()
bool HasEnvironmentMap ( ) const
◆ HasLightMap()
bool HasLightMap ( ) const
True if this material has a light map
◆ HasMetalnessMap()
bool HasMetalnessMap ( ) const
◆ HasNormalMap()
bool HasNormalMap ( ) const
◆ HasRoughnessMap()
bool HasRoughnessMap ( ) const
◆ HasTexture()
bool HasTexture ( ) const
◆ LightingEnabled()
bool LightingEnabled ( ) const
◆ LightMap()
std::string LightMap ( ) const
◆ LightMapTexCoordSet()
unsigned int LightMapTexCoordSet ( ) const
texture coordinate set of the light map
◆ Metalness()
float Metalness ( ) const
Material metalness
◆ MetalnessMap()
std::string MetalnessMap ( ) const
◆ NormalMap()
std::string NormalMap ( ) const
void PreRender ( )
◆ ReceiveShadows()
bool ReceiveShadows ( ) const
◆ ReflectionEnabled()
bool ReflectionEnabled ( ) const
◆ Reflectivity()
double Reflectivity ( ) const
The reflectivity value
◆ RenderOrder()
float RenderOrder ( ) const
◆ Reset()
void Reset ( )
◆ Roughness()
float Roughness ( ) const
Material roughness
◆ RoughnessMap()
std::string RoughnessMap ( ) const
◆ SetAlphaFromTexture()
void SetAlphaFromTexture ( bool  _enabled,
double  _alpha = 0.5,
bool  _twoSided = true
Referenced by BaseMaterial< OgreObject >::CopyFrom().
◆ SetAmbient() [1/2]
void SetAmbient ( const double  _r,
const double  _g,
const double  _b,
const double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Referenced by BaseMaterial< OgreObject >::CopyFrom(), BaseMaterial< OgreObject >::Reset(), and BaseMaterial< OgreObject >::SetAmbient().
◆ SetAmbient() [2/2]
void SetAmbient ( const math::Color &  _color)
[in]_colorNew ambient color
◆ SetCastShadows()
void SetCastShadows ( const bool  _castShadows)
◆ SetDepthCheckEnabled()
void SetDepthCheckEnabled ( bool  _enabled)
◆ SetDepthMaterial()
void SetDepthMaterial ( const double  far,
const double  near
◆ SetDepthWriteEnabled()
void SetDepthWriteEnabled ( bool  _enabled)
◆ SetDiffuse() [1/2]
void SetDiffuse ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Referenced by BaseMaterial< OgreObject >::CopyFrom(), BaseMaterial< OgreObject >::Reset(), and BaseMaterial< OgreObject >::SetDiffuse().
◆ SetDiffuse() [2/2]
void SetDiffuse ( const math::Color &  _color)
[in]_colorNew diffuse color
◆ SetEmissive() [1/2]
void SetEmissive ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Referenced by BaseMaterial< OgreObject >::CopyFrom(), BaseMaterial< OgreObject >::Reset(), and BaseMaterial< OgreObject >::SetEmissive().
◆ SetEmissive() [2/2]
void SetEmissive ( const math::Color &  _color)
[in]_colorNew emissive color
◆ SetEmissiveMap()
void SetEmissiveMap ( const std::string &  _emissiveMap)
[in]_emissiveMapURI of the new emissive map file
◆ SetEnvironmentMap()
void SetEnvironmentMap ( const std::string &  _metalnessMap)
[in]_metalnessMapURI of the new environment map file
◆ SetFragmentShader()
void SetFragmentShader ( const std::string &  _path)
Referenced by BaseMaterial< OgreObject >::CopyFrom(), and BaseMaterial< OgreObject >::ShaderType().
◆ SetLightingEnabled()
void SetLightingEnabled ( const bool  _enabled)
◆ SetLightMap()
void SetLightMap ( const std::string &  _lightMap,
unsigned int  _uvSet = 0u
[in]_lightMapURI of the new light map file
[in]_uvSetTexture coordinate set to use
◆ SetMetalness()
void SetMetalness ( const float  _metalness)
◆ SetMetalnessMap()
void SetMetalnessMap ( const std::string &  _metalnessMap)
[in]_metalnessMapURI of the new metalness map file
◆ SetNormalMap()
void SetNormalMap ( const std::string &  _normalMap)
[in]_normalMapURI of the new normal map file
◆ SetReceiveShadows()
void SetReceiveShadows ( const bool  _receiveShadows)
◆ SetReflectionEnabled()
void SetReflectionEnabled ( const bool  _enabled)
◆ SetReflectivity()
void SetReflectivity ( const double  _reflectivity)
◆ SetRenderOrder()
void SetRenderOrder ( const float  _renderOrder)
◆ SetRoughness()
void SetRoughness ( const float  _roughness)
◆ SetRoughnessMap()
void SetRoughnessMap ( const std::string &  _roughnessMap)
[in]_roughnessMapURI of the new roughness map file
◆ SetShaderType()
inlineoverridevirtual
[in]_typeNew ShaderType value
◆ SetShininess()
void SetShininess ( const double  _shininess)
◆ SetSpecular() [1/2]
void SetSpecular ( const double  _r,
const double  _g,
const double  _b,
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Referenced by BaseMaterial< OgreObject >::CopyFrom(), BaseMaterial< OgreObject >::Reset(), and BaseMaterial< OgreObject >::SetSpecular().
◆ SetSpecular() [2/2]
void SetSpecular ( const math::Color &  _color)
[in]_colorNew specular color
◆ SetTexture()
void SetTexture ( const std::string &  _texture)
[in]_textureURI of the new texture file
◆ SetTransparency()
void SetTransparency ( const double  _transparency)
◆ SetVertexShader()
void SetVertexShader ( const std::string &  _path)
◆ ShaderType()
The ShaderType value
◆ Shininess()
double Shininess ( ) const
The shininess value
◆ Specular()
math::Color Specular ( ) const
The specular color
◆ Texture()
std::string Texture ( ) const
◆ TextureAlphaEnabled()
bool TextureAlphaEnabled ( ) const
The enable alpha value
◆ Transparency()
double Transparency ( ) const
The transparency value
◆ TwoSidedEnabled()
bool TwoSidedEnabled ( ) const
The enable two sided rendering value
◆ Type()
MaterialType Type ( ) const
◆ VertexShader()
std::string VertexShader ( ) const
Path to vertex shader
◆ VertexShaderParams()
ShaderParamsPtr VertexShaderParams ( )
editable parameters
◆ alphaThreshold
Referenced by BaseMaterial< OgreObject >::AlphaThreshold(), and BaseMaterial< OgreObject >::SetAlphaFromTexture().
◆ ambient
◆ castShadows
Referenced by BaseMaterial< OgreObject >::CastShadows(), and BaseMaterial< OgreObject >::SetCastShadows().
◆ depthCheckEnabled
Referenced by BaseMaterial< OgreObject >::DepthCheckEnabled(), and BaseMaterial< OgreObject >::SetDepthCheckEnabled().
◆ depthWriteEnabled
Referenced by BaseMaterial< OgreObject >::DepthWriteEnabled(), and BaseMaterial< OgreObject >::SetDepthWriteEnabled().
◆ diffuse
◆ emissive
◆ lightingEnabled
Referenced by BaseMaterial< OgreObject >::LightingEnabled(), and BaseMaterial< OgreObject >::SetLightingEnabled().
◆ receiveShadows
◆ reflectionEnabled
Referenced by BaseMaterial< OgreObject >::ReflectionEnabled(), and BaseMaterial< OgreObject >::SetReflectionEnabled().
◆ reflectivity
◆ renderOrder
◆ shininess
◆ specular
◆ textureAlphaEnabled
Referenced by BaseMaterial< OgreObject >::SetAlphaFromTexture(), and BaseMaterial< OgreObject >::TextureAlphaEnabled().
◆ transparency
Referenced by BaseMaterial< OgreObject >::SetTransparency(), and BaseMaterial< OgreObject >::Transparency().
◆ twoSidedEnabled
