Ogre 2.x implementation of the material class. More...
#include <Ogre2Material.hh>
virtual ~Ogre2Material ()
virtual void ClearLightMap () override
virtual Ogre::HlmsPbsDatablock * Datablock () const
 Return ogre Hlms material pbs datablock. More...
virtual void FillUnlitDatablock (Ogre::HlmsUnlitDatablock *_datablock) const
 Fill the input unlit datablock with current material properties from the pbs datablock. More...
virtual bool HasLightMap () const override
virtual std::string LightMap () const override
virtual unsigned int LightMapTexCoordSet () const override
virtual Ogre::MaterialPtr Material ()
 Return ogre low level material. More...
virtual float RenderOrder () const override
virtual void SetAlphaFromTexture (bool _enabled, double _alpha=0.5, bool _twoSided=true) override
virtual void SetEmissiveMap (const std::string &_emissiveMap) override
virtual void SetEnvironmentMap (const std::string &_metalnessMap) override
virtual void SetLightMap (const std::string &_lightMap, unsigned int _uvSet=0u) override
virtual void SetMetalness (const float _roughness) override
virtual void SetMetalnessMap (const std::string &_metalnessMap) override
virtual void SetNormalMap (const std::string &_normalMap) override
virtual void SetRenderOrder (const float _renderOrder) override
virtual void SetRoughnessMap (const std::string &_roughnessMap) override
virtual void SetTexture (const std::string &_texture) override
virtual enum MaterialType Type () const override
virtual Ogre::HlmsUnlitDatablock * UnlitDatablock ()
 Return ogre Hlms material unlit datablock. More...
- Public Member Functions inherited from BaseMaterial< Ogre2Object >
virtual ~BaseMaterial ()
double AlphaThreshold () const override
 Clone this material. More...
bool TextureAlphaEnabled () const override
bool TwoSidedEnabled () const override
virtual ~Material ()
 Ogre2Material ()
virtual void SetTextureMapImpl (const std::string &_texture, Ogre::PbsTextureTypes _type)
 Set the texture map for this material. More...
virtual Ogre::TextureGpu * Texture (const std::string &_name)
 Get a pointer to the ogre texture by name. More...
virtual void UpdateTransparency ()
 Updates the material transparency in the engine, based on transparency and diffuse alpha values. More...
- Protected Member Functions inherited from BaseMaterial< Ogre2Object >
 BaseMaterial ()
std::string emissiveMapName
 Name of the emissive map. More...
std::string environmentMapName
 Name of the environment map. More...
std::string lightMapName
 Name of the light map. More...
unsigned int lightMapUvSet = 0u
 Texture coorindate set used by the light map. More...
std::string metalnessMapName
 Name of the metalness map. More...
std::string normalMapName
 Name of the normal map. More...
Ogre::HlmsPbsDatablock * ogreDatablock = nullptr
 Ogre data block containing all pbs material properties. More...
std::string ogreDatablockId
 Unique id assigned to ogre hlms datablock. More...
Ogre::HlmsPbs * ogreHlmsPbs = nullptr
 Ogre high level physical based shading object. More...
Ogre::MaterialPtr ogreMaterial
 Ogre material. Mainly used for render targets. More...
Ogre::HlmsUnlitDatablock * ogreUnlitDatablock = nullptr
 Ogre data block containing all unlit material properties. More...
std::string roughnessMapName
 Name of the roughness map. More...
std::string textureName
 Name of the texture. More...
- Protected Attributes inherited from BaseMaterial< Ogre2Object >
double alphaThreshold
 Threshold for alpha channel rejection. More...
math::Color ambient
 Ambient color. More...
bool castShadows
bool depthCheckEnabled
bool depthWriteEnabled
math::Color diffuse
 Diffuse color. More...
math::Color emissive
 Emissive color. More...
bool lightingEnabled
bool receiveShadows
bool reflectionEnabled
double reflectivity
 Reflectivity. More...
double renderOrder
 Material render order. More...
double shininess
 Shininess factor. More...
math::Color specular
 Specular color. More...
bool textureAlphaEnabled
 Enable alpha channel based texture transparency. More...
double transparency
bool twoSidedEnabled
 Enable two sided rendering. More...
◆ Ogre2Material()
Ogre2Material ( )
◆ ~Ogre2Material()
virtual ~Ogre2Material ( )
◆ ClearEmissiveMap()
virtual void ClearEmissiveMap ( )
Reimplemented from BaseMaterial< Ogre2Object >.
◆ ClearEnvironmentMap()
virtual void ClearEnvironmentMap ( )
◆ ClearLightMap()
virtual void ClearLightMap ( )
◆ ClearMetalnessMap()
virtual void ClearMetalnessMap ( )
◆ ClearNormalMap()
◆ ClearRoughnessMap()
virtual void ClearRoughnessMap ( )
◆ ClearTexture()
virtual void ClearTexture ( )
◆ Datablock()
virtual Ogre::HlmsPbsDatablock* Datablock ( ) const
Ogre Hlms pbs datablock
◆ DepthCheckEnabled()
◆ DepthWriteEnabled()
◆ Diffuse()
The diffuse color
◆ Emissive()
The emissive color
◆ EmissiveMap()
virtual std::string EmissiveMap ( ) const
◆ EnvironmentMap()
virtual std::string EnvironmentMap ( ) const
◆ FillUnlitDatablock()
virtual void FillUnlitDatablock ( Ogre::HlmsUnlitDatablock *  _datablock) const
[in]_datablockUnlit datablock to fill
◆ HasEmissiveMap()
virtual bool HasEmissiveMap ( ) const
◆ HasEnvironmentMap()
virtual bool HasEnvironmentMap ( ) const
◆ HasLightMap()
virtual bool HasLightMap ( ) const
True if this material has a light map
◆ HasMetalnessMap()
virtual bool HasMetalnessMap ( ) const
◆ HasNormalMap()
◆ HasRoughnessMap()
virtual bool HasRoughnessMap ( ) const
◆ HasTexture()
◆ LightMap()
virtual std::string LightMap ( ) const
◆ LightMapTexCoordSet()
virtual unsigned int LightMapTexCoordSet ( ) const
texture coordinate set of the light map
virtual Ogre::MaterialPtr Material ( )
Ogre material pointer
◆ Metalness()
virtual float Metalness ( ) const
Material metalness
◆ MetalnessMap()
virtual std::string MetalnessMap ( ) const
◆ NormalMap()
◆ ReceiveShadows()
◆ RenderOrder()
◆ Roughness()
virtual float Roughness ( ) const
Material roughness
◆ RoughnessMap()
virtual std::string RoughnessMap ( ) const
◆ SetAlphaFromTexture()
double  _alpha = 0.5,
bool  _twoSided = true
◆ SetDepthCheckEnabled()
◆ SetDepthWriteEnabled()
◆ SetDiffuse()
[in]_colorNew diffuse color
◆ SetEmissive()
[in]_colorNew emissive color
◆ SetEmissiveMap()
virtual void SetEmissiveMap ( const std::string &  _emissiveMap)
[in]_emissiveMapURI of the new emissive map file
◆ SetEnvironmentMap()
virtual void SetEnvironmentMap ( const std::string &  _metalnessMap)
[in]_metalnessMapURI of the new environment map file
◆ SetLightMap()
virtual void SetLightMap ( const std::string &  _lightMap,
unsigned int  _uvSet = 0u
[in]_lightMapURI of the new light map file
[in]_uvSetTexture coordinate set to use
◆ SetMetalness()
virtual void SetMetalness ( const float  _metalness)
◆ SetMetalnessMap()
virtual void SetMetalnessMap ( const std::string &  _metalnessMap)
[in]_metalnessMapURI of the new metalness map file
◆ SetNormalMap()
virtual void SetNormalMap ( const std::string &  _normalMap)
[in]_normalMapURI of the new normal map file
◆ SetReceiveShadows()
◆ SetRenderOrder()
◆ SetRoughness()
virtual void SetRoughness ( const float  _roughness)
◆ SetRoughnessMap()
virtual void SetRoughnessMap ( const std::string &  _roughnessMap)
[in]_roughnessMapURI of the new roughness map file
◆ SetSpecular()
[in]_colorNew specular color
◆ SetTexture()
virtual void SetTexture ( const std::string &  _texture)
[in]_textureURI of the new texture file
◆ SetTextureMapImpl()
virtual void SetTextureMapImpl ( const std::string &  _texture,
[in]_textureName of the texture.
[in]_typeType of texture, i.e. diffuse, normal, roughness, metalness
◆ SetTransparency()
◆ Specular()
The specular color
◆ Texture() [1/2]
◆ Texture() [2/2]
virtual Ogre::TextureGpu* Texture ( const std::string &  _name)
Ogre texture
◆ Type()
virtual enum MaterialType Type ( ) const
◆ UnlitDatablock()
virtual Ogre::HlmsUnlitDatablock* UnlitDatablock ( )
Ogre Hlms unlit datablock
◆ UpdateTransparency()
virtual void UpdateTransparency ( )
◆ emissiveMapName
◆ environmentMapName
◆ lightMapName
◆ lightMapUvSet
◆ metalnessMapName
◆ normalMapName
◆ ogreDatablock
Ogre::HlmsPbsDatablock* ogreDatablock = nullptr
◆ ogreDatablockId
◆ ogreHlmsPbs
Ogre::HlmsPbs* ogreHlmsPbs = nullptr
◆ ogreMaterial
◆ ogreUnlitDatablock
Ogre::HlmsUnlitDatablock* ogreUnlitDatablock = nullptr
◆ roughnessMapName
◆ textureName
