| virtual | ~BasePointLight () |
| virtual | ~PointLight () |
| | Destructor. More...
| virtual | ~Light () |
| | Destructor. More...
| virtual double | AttenuationConstant () const =0 |
| | Get the attenuation constant value. More...
| virtual double | AttenuationLinear () const =0 |
| | Get the attenuation linear value. More...
| virtual double | AttenuationQuadratic () const =0 |
| | Get the attenuation quadratic value. More...
| virtual double | AttenuationRange () const =0 |
| | Get the attenuation range. More...
| virtual bool | CastShadows () const =0 |
| | Determine if this light cast shadows. More...
| virtual math::Color | DiffuseColor () const =0 |
| | Get the diffuse color. More...
| virtual double | Intensity () const =0 |
| | Get the light intensity. More...
| virtual void | SetAttenuationConstant (double _value)=0 |
| | Set the attenuation constant value. More...
| virtual void | SetAttenuationLinear (double _value)=0 |
| | Set the attenuation linear value. More...
| virtual void | SetAttenuationQuadratic (double _value)=0 |
| | Set the attenuation quadratic value. More...
| virtual void | SetAttenuationRange (double _range)=0 |
| | Set the attenuation range. More...
| virtual void | SetCastShadows (bool _castShadows)=0 |
| | Specify if this light should cast shadows. More...
| virtual void | SetDiffuseColor (double _r, double _g, double _b, double _a=1.0)=0 |
| | Set the diffuse color. More...
| virtual void | SetDiffuseColor (const math::Color &_color)=0 |
| virtual void | SetIntensity (double _intensity)=0 |
| | Set the light intensity. More...
| virtual void | SetSpecularColor (double _r, double _g, double _b, double _a=1.0)=0 |
| | Set the specular color. More...
| virtual void | SetSpecularColor (const math::Color &_color)=0 |
| virtual math::Color | SpecularColor () const =0 |
| | Get the specular color. More...
| virtual | ~Node () |
| | Destructor. More...
| | Destructor. More...
