BaseRenderTarget< T > Class Template Referenceabstract
 BaseRenderTarget ()
virtual ~BaseRenderTarget ()
virtual ~RenderTarget ()
virtual void Rebuild ()
virtual void RebuildImpl ()=0
PixelFormat format = PF_UNKNOWN
unsigned int height = 0u
bool renderPassDirty = false
bool targetDirty = true
unsigned int width = 0u
◆ BaseRenderTarget()
◆ ~BaseRenderTarget()
~BaseRenderTarget ( )
◆ AddRenderPass()
Implements RenderTarget.
◆ BackgroundColor()
math::Color BackgroundColor ( ) const
Reimplemented in Ogre2RenderTarget, and OgreRenderTarget.
◆ Format()
PixelFormat Format ( ) const
Render target format
◆ Height()
unsigned int Height ( ) const
◆ PostRender()
void PostRender ( )
Reimplemented in Ogre2RenderTexture, OgreRenderTexture, Ogre2RenderTarget, and OgreRenderTarget.
void PreRender ( )
◆ Rebuild()
void Rebuild ( )
◆ RebuildImpl()
virtual void RebuildImpl ( )
protectedpure virtual
◆ RemoveRenderPass()
◆ RenderPassByIndex()
◆ RenderPassCount()
◆ SetFormat()
void SetFormat ( PixelFormat  _format)
[in]_formatNew target format
◆ SetHeight()
void SetHeight ( const unsigned int  _height)
◆ SetWidth()
void SetWidth ( const unsigned int  _width)
◆ Width()
unsigned int Width ( ) const
◆ format
◆ height
◆ renderPassDirty
Referenced by BaseRenderTarget< OgreObject >::AddRenderPass(), and BaseRenderTarget< OgreObject >::RemoveRenderPass().
◆ renderPasses
◆ targetDirty
◆ width
