RenderTarget Class Referenceabstract
#include <ignition/rendering/RenderTarget.hh>
virtual ~RenderTarget ()
◆ ~RenderTarget()
◆ AddRenderPass()
Implemented in BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
Referenced by RenderTarget::~RenderTarget().
◆ BackgroundColor()
Implemented in Ogre2RenderTarget, BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, BaseRenderTarget< OgreObject >, and OgreRenderTarget.
◆ Copy()
Implemented in Ogre2RenderTarget, and OgreRenderTarget.
◆ Format()
virtual PixelFormat Format ( ) const
Render target format
◆ Height()
virtual unsigned int Height ( ) const
◆ RemoveRenderPass()
◆ RenderPassByIndex()
◆ RenderPassCount()
◆ SetFormat()
virtual void SetFormat ( PixelFormat  _format)
[in]_formatNew target format
◆ SetHeight()
virtual void SetHeight ( const unsigned int  _height)
◆ SetWidth()
virtual void SetWidth ( const unsigned int  _width)
◆ Width()
virtual unsigned int Width ( ) const
