BaseSceneStore< T > Class Template Reference
#include <BaseRenderTypes.hh>
Public Member Functions inherited from BaseStore< Scene, T > | |
| BaseStore () | |
| virtual | ~BaseStore () |
| virtual bool | Add (TPtr _object) |
| Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done. More... | |
| virtual bool | AddDerived (UPtr _object) |
| virtual UIter | Begin () |
| Return an iterator to the beginning. More... | |
| virtual bool | Contains (ConstTPtr _object) const |
| Determine if store contains the given element. More... | |
| virtual bool | ContainsId (unsigned int _id) const |
| Determine if store contains the element with the given ID. More... | |
| virtual bool | ContainsName (const std::string &_name) const |
| Determine if store contains the element with the given name. More... | |
| virtual UPtr | DerivedById (unsigned int _id) const |
| virtual UPtr | DerivedByIndex (unsigned int _index) const |
| virtual UPtr | DerivedByName (const std::string &_name) const |
| virtual void | Destroy (TPtr _object) |
| Remove and destroy given element. If the given element does not exists, in this store, then no work will be done. More... | |
| virtual void | DestroyAll () |
| Remove and destroy all elements in store. More... | |
| virtual void | DestroyById (unsigned int _id) |
| Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual void | DestroyByIndex (unsigned int _index) |
| Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual void | DestroyByName (const std::string &_name) |
| Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual UIter | End () |
| Return an iterator to the end. More... | |
| virtual TPtr | GetById (unsigned int _id) const |
| Get element with the given ID. More... | |
| virtual TPtr | GetByIndex (unsigned int _index) const |
| Get element at the given index. More... | |
| virtual TPtr | GetByName (const std::string &_name) const |
| Get element with the given name. More... | |
| virtual TPtr | Remove (TPtr _object) |
| Remove given element. If the given element does not exists in this store, then no work will be done. More... | |
| virtual void | RemoveAll () |
| Remove all elements from store. More... | |
| virtual TPtr | RemoveById (unsigned int _id) |
| Remove element with the given ID. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual TPtr | RemoveByIndex (unsigned int _index) |
| Remove element at the given index. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual TPtr | RemoveByName (const std::string &_name) |
| Remove element with the given name. If the specified element does not exists in this store, then no work will be done. More... | |
| virtual UPtr | RemoveDerived (UPtr _object) |
| virtual UPtr | RemoveDerivedById (unsigned int _id) |
| virtual UPtr | RemoveDerivedByIndex (unsigned int _index) |
| virtual UPtr | RemoveDerivedByName (const std::string &_name) |
| virtual unsigned int | Size () const |
| Get number of elements in this store. More... | |
Public Member Functions inherited from Store< Scene > | |
| virtual | ~Store () |
| Destructor. More... | |
Protected Member Functions inherited from BaseStore< Scene, T > | |
| virtual bool | AddImpl (UPtr _object) |
| virtual ConstUIter | ConstIter (ConstTPtr _object) const |
| virtual ConstUIter | ConstIterById (unsigned int _id) const |
| virtual ConstUIter | ConstIterByIndex (unsigned int _index) const |
| virtual ConstUIter | ConstIterByName (const std::string &_name) const |
| virtual void | DestroyImpl (UIter _iter) |
| virtual bool | IsValidIter (ConstUIter _iter) const |
| virtual UIter | Iter (ConstTPtr _object) |
| virtual UIter | IterById (unsigned int _id) |
| virtual UIter | IterByIndex (unsigned int _index) |
| virtual UIter | IterByName (const std::string &_name) |
| virtual UIter | RemoveConstness (ConstUIter _iter) |
| virtual UPtr | RemoveImpl (UIter _iter) |
Protected Attributes inherited from BaseStore< Scene, T > | |
| UStore | store |
