Geometry for a capsule shape. More...
#include <ignition/rendering/Capsule>
| virtual | ~Capsule () |
| Destructor. More... | |
| virtual double | Length () const =0 |
| Get the length of the capsule. More... | |
| virtual double | Radius () const =0 |
| Get the radius of the capsule. More... | |
| virtual void | SetLength (double _length)=0 |
| Set the length of the capsule. More... | |
| virtual void | SetRadius (double _radius)=0 |
| Set the radius of the capsule. More... | |
| virtual | ~Geometry () |
| virtual VisualPtr | Parent () const =0 |
◆ ~Capsule()
inlinevirtual |
References Capsule::Length(), Capsule::Radius(), Capsule::SetLength(), and Capsule::SetRadius().
◆ Length()
pure virtual |
Implemented in BaseCapsule< T >, BaseCapsule< Ogre2Geometry >, and BaseCapsule< OgreGeometry >.
Referenced by Capsule::~Capsule().
◆ Radius()
pure virtual |
◆ SetLength()
pure virtual |
◆ SetRadius()
pure virtual |
