Geometry Class Referenceabstract
#include <ignition/rendering/Geometry.hh>
 Clone the geometry. More...
◆ ~Geometry()
◆ Clone()
◆ HasParent()
Implemented in Ogre2Geometry, and OgreGeometry.
Referenced by Geometry::~Geometry().
◆ Parent()
◆ RemoveParent()
virtual void RemoveParent ( )
Implemented in BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [1/2]
bool  _unique = true
Implemented in BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
Referenced by Geometry::~Geometry(), and SubMesh::~SubMesh().
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, Ogre2Heightmap, OgreHeightmap, Ogre2Capsule, OgreCapsule, OgreText, OgreGrid, OgreWireBox, Ogre2Grid, Ogre2WireBox, OgreMarker, Ogre2Marker, BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
