Ogre 2.x implementation of a Lidar Visual. More...
#include <Ogre2LidarVisual.hh>
virtual ~Ogre2LidarVisual ()
 Update the Visual. More...
- Public Member Functions inherited from BaseLidarVisual< Ogre2Visual >
virtual ~BaseLidarVisual ()
virtual ignition::math::Pose3d Offset () const override
 Get offset of visual. More...
virtual void SetOffset (const ignition::math::Pose3d _offset) override
 Set offset of visual. More...
virtual void SetPoints (const std::vector< double > &_points, const std::vector< ignition::math::Color > &_colors) override
virtual ~LidarVisual ()
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2LidarVisual ()
- Protected Member Functions inherited from BaseLidarVisual< Ogre2Visual >
 BaseLidarVisual ()
 LidarVisual ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseLidarVisual< Ogre2Visual >
bool displayNonHitting
double horizontalAngleStep
unsigned int horizontalCount
double maxHorizontalAngle
double maxRange
 Maximum Range. More...
double maxVerticalAngle
double minHorizontalAngle
double minRange
 Minimum Range. More...
double minVerticalAngle
ignition::math::Pose3d offset
 Offset of visual. More...
double size
double verticalAngleStep
unsigned int verticalCount
 Vertical laser count. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2LidarVisual()
Ogre2LidarVisual ( )
◆ ~Ogre2LidarVisual()
virtual ~Ogre2LidarVisual ( )
◆ ClearPoints()
virtual void ClearPoints ( )
Reimplemented from BaseLidarVisual< Ogre2Visual >.
◆ PointCount()
◆ Points()
The points in the laser data
◆ SetPoints()
◆ SetVisible()
Reimplemented from Ogre2Visual.
virtual void Update ( )
Update the Visual.
